Old 07-26-2020, 08:59 PM   #1
BigTruckDriver
BigTruckDriver's Avatar
Lowering rear 1.5"?
What are my options with the least amount of modifications? Not looking to cut bed support for a 2" shackle.
BigTruckDriver is offline   Reply With Quote
Old 07-26-2020, 09:25 PM   #2
sweetk30
sweetk30's Avatar
Re: Lowering rear 1.5"?
drop springs or drop hanger for the front spring eye location.
i did mine with the drop hanger and shackle to get it dialed in . i just moved my hanger up and re-drilled the holes and used 7/16 bolts with stover / crimp lock nuts . then the rear i did have to notch the crossmember on the box for the shackle .
but mine i went down 2.5" front and rear . so if you did just hanger in the rear at the front of the leaf spring you will prob be fine i think . just be sure to check pinion angle .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 07-27-2020, 09:24 AM   #3
bigblock73
yeller
bigblock73's Avatar
If you have the longer HD springs, a drop shackle will clear the bed support. The shorter LD springs are the ones that will interfere with a drop shackle.
bigblock73 is offline   Reply With Quote
Old 07-27-2020, 12:25 PM   #4
sweetk30
sweetk30's Avatar
std issue is 52" eye to eye .
hd is the 56" eye to eye . and its 4" longer on the back side only .
and the shackle hanger bracket is back 4" in the extra frame holes . most i have seen have the extra frame holes already there .
Old 07-27-2020, 01:57 PM   #5
bigblock73
yeller
bigblock73's Avatar
You are correct.
Old 07-27-2020, 09:40 PM   #6
BigTruckDriver
Looks like drop leaf springs are going to be my best bet. I am also looking to pull a trailer . Any reputable place to purchase from?
Old 07-27-2020, 10:16 PM   #7
MikeB
MikeB's Avatar
Problem with just doing raised hangers or longer shackles (and not both) is the pinion angle will change and you will need angled spring shims to raise or lower the differential nose. if I had a do-over, I'd go with lowered springs.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 07-30-2020, 12:56 PM   #8
Keith Seymore
Keith Seymore's Avatar
You could raise the production spring hangers on the frame rail.
http://67-72chevytrucks.com/vboard/s...d.php?t=509224
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-04-2020, 01:54 PM   #9
72c20customcamper
72c20customcamper's Avatar
I bought my lowering leafs from Western chassis. They are not to got on communication and took 12 business days to get the rears still waiting on the fronts UPS says Thursday. But the leafs I got look to be very nice and came from st Loius spring . I'd get a picture but right now were getting hammered with wind and rain
If I had known I would have ordered directly from them
http://www.saintlouisspring.com/
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-04-2020, 06:17 PM   #10
72c20customcamper
An hour ago we had 50 plus sustained winds and heavy rain . Now its calm and sunny . Pic of the newleafs old leafs are 8 new ones are 10 and American made
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
