11-11-2020, 11:01 PM | #1 |
chevy truck fan
DBW pedal connection ??
I am in the process of LS swapping a 2013 4.8L truck engine into a 1986 swb 2wd truck. I am trying to figure out how to connect the DBW pedal. I have the pedal connector pigtail and I have ID the corresponding ECM wires. I am wanting to know how to “connect” the wires together?? I have included the factory wire diagram for the pedal. Any help would be greatly appreciated
thanks!! Rodstored-72 |
11-12-2020, 11:07 AM | #2 |
Re: DBW pedal connection ??
Not sure if you need the BCM or not. My set up uses a TCM box.
I wonder if the Pedal sends an analog (rheostat) type signal to the BCM which turns it into a data signal to the throttle body? Someone with a newer set up will have to chime in to be sure if you need the BCM or not.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
11-12-2020, 11:08 AM | #3 |
Solder and heat shrink is how I would do it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
11-12-2020, 05:42 PM | #4 |
Just looking at the photo again. Are those the twisted wires in the middle?
11-12-2020, 09:10 PM | #5 |
BMW & ASE Master Certified
what do you mean connect them, one at a time? do you need ecu terminals? pedal terminals? crimper recommendations?
im sure i have plenty of terminals for the ls ecu round pin, e38, e92 ecus aswell.. solder and heat shrink also works.. in the builds i do, I have a interior connector on the engine harness. it has all 6 pedal wires, obd, brake signal, a/c request, rpm, mph all the normal stuff going to ecu but in the engine bay, similar to the diagram you have theres a connector so if you needed to remove the engine harness, connector. clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
11-14-2020, 01:28 AM | #6 | ||
chevy truck fan
... well I was thinking that, but I am looking to make sure that the wires ONLY need to be connected together via twisted pair directly from the ECM to the APP (truck pedal)
11-14-2020, 04:33 PM | #7 |
None of the pedal wires are twisted. You just need to connect connect the 6 individual wires and solder and heat shrink would be my method of splicing.
11-15-2020, 11:22 AM | #8 |
pedal wires are not twisted together.
11-16-2020, 01:01 AM | #9 |
chevy truck fan
I have been able to confirm that the 6 pedal wires can just be connected together from each end.... meaning IE: the purple wire from the ECM can be directly connected (solder/connector) to the purple wire at the pedal end. I am not sure why the factory diagram show to be twisted? maybe the length or other wires that are typically ran in the same loom?? anyways I am going to use a 6 way connector & and connect the 6 color wires individually.
thanks! |
11-16-2020, 09:26 AM | #10 | |
Again, Diagram does not show them to be twisted. Research diagrams more It is showing options, such as engine type or transmission. Clint
