Old 11-22-2020, 06:35 PM   #1
Reno
Reno's Avatar
Enlarged Spare tire tub
Has anyone enlarged their spare tire tub?
I’m running 34” x 10” tires and would like to store it in the factory location but it won’t fit.....
I see they make enlarged wheel tubs for blazers and trucks that maybe I could use inverted?
Or might have to fab up larger suburban spare tire tub...
Reno is offline   Reply With Quote
Old 11-24-2020, 08:45 PM   #2
HO455
Post Whore
HO455's Avatar
Re: Enlarged Spare tire tub
I believe it would be easier to add material to your existing one than try to convert something else. I'm pretty sure one of the floor stiffeners would have to be shortened.
Before committing to this I would make sure the diameter of the tire will fit the space. A cardboard mock up would get the answers needed.
I found a picture of the well removed it may help you.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 11-27-2020, 11:47 AM   #3
19Suburban69
I just put my "big" tire over the opening and used a tie down strap to hold it. Then used the tub for storage.
1955 Chevy, 2 dr post, my first car
1969 Chevy C20 Suburban, 6.0 LS w/4L80
2001 Silverado Z71, 5.3 extended cab
19Suburban69 is offline   Reply With Quote
Old 11-29-2020, 06:45 PM   #4
CG
BlahBlahBlah
I always thought a nicely done roof rack would make a good place to put a spare up top. Put a cover over it. Or if you use it much off road, make it a cool place to put a high lift jack, maybe a couple of jerry cans and maybe a shovel.
Monroe Swap meet May 18-19.
Mike has the same spots for the NW guys he's had forever.
Lunch time BBQ at the spaces.
If you have stuff to sell bring it along.
If you have a question PM stllookn (Mike) here via the board.
https://67-72chevytrucks.com/vboard/...d.php?t=851291
Old 12-11-2020, 05:15 PM   #5
Burb
Coordinator of Synchronicity
Burb's Avatar
Had to replace mine and will probably mount batteries in it now
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
