10-03-2011, 11:11 PM | #1 |
700R4 and TH400 Torque Converter?
Does anyone know if the Torque Converters from the TH400 and the 700R4 are the same? I bought a new one for a TH400 I have and I would like to use it on the 700R4 if it will work.
Thanks for any help. JRBECK64 |
10-04-2011, 01:13 AM | #2 |
Re: 700R4 and TH400 Torque Converter?
No it will not. The 700R4 has a lock up torque converter and the TH-400 does not. You will need to buy one based on the year of your trans too. I found out the hard way that different years of 700R4's have different spline counts on the trans input shaft.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
10-04-2011, 10:27 AM | #3 |
No
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
10-04-2011, 11:39 AM | #4 | |
JRBECK64 |
09-28-2017, 03:05 PM | #5 |
I have a '75 GMC motorhome that the transmission went.
It's a TH400 and there is a good deal on a 700R4. Should I convert to the 700 and would it be costly ? Anyone ? |
09-28-2017, 03:10 PM | #6 | |
edit, I would say no way
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
09-28-2017, 03:13 PM | #7 |
Ok. Thanks !
I will look for another 400. |
