Re: Site feature trucks list and information
5 Attachment(s)
Here is my 72 C20 Cheynne Super. I bought it back in 94 after an accident in a 69 GMC C20, long story but I only paid $150 for it. It originally came with the big block 400, T400 trans, AC, Tilt, AM/FM Push Button Radio, Houndstooth Seat and Overloads springs. I built a 511 CI, Perf Built T400 trans with Gear Vendors and 4.10 rear gears. Tri-Y headers with 3" exhaust and 40 series Flowmasters. Interior has been sprayed with Lizardskin heat / sound barrier and also Flatline Barrier placed on top with new carpet. Customer Auto Sound stereo with 6x9 cab corner speakers and a 8" Bazooka Bass. Fuel tank removed from behind the seat and installed a Boyds custom made 30 gallon fuel tank that is behind the rear axle. Installed a Fi-Tech Fuel injection with an Aeromotive In-Tank fuel pump. Widened steel rims - rear are 16x10 and front are 16x8. Customer built Wizard radiator with 2 x 14" SPAL brushless fans that are PWM. AC has been converted to R134A and kept as close to stock looking as I could get.
Attachment 2266516 Attachment 2266517 Attachment 2266518 Attachment 2266519 Attachment 2266520 Continued |
4 Attachment(s)
Here are a few more pics -
Attachment 2266521 Attachment 2266522 Attachment 2266523 Attachment 2266524 |
5 Attachment(s)
Not sure if this was only for certain trucks but I thought I would include my 2000 S10 Xtreme drag truck.
I bought and built this truck back in 2013. It is currently running a 374 CI small block which has a Dart Little M block, Callies crank, Manly rods, Diamond 14.5 CR pistons, Comp Solid Roller cam, Dart Pro1 heads that has been port matched to a Dart intake, T7D Shaft Rockers. ATI Pro T400 trans with a 9" converter, 4" aluminum driveline, S& W Backhalf 4-link, 9" rear with Strange Aluminum center section with spool and 4.71 gears. 32x14x15 Good Year slicks. Front runs QA-1 Pro Coils with TRZ upper/lower tubular control arms. Attachment 2266525 Attachment 2266526 Attachment 2266527 Attachment 2266528 Attachment 2266529 Continued |
2 Attachment(s)
Information on how to submit is in the first post. Thanks!
