Re: Pre Valentines 2014 67-72 trucks parts SPECIAL
Randy, thanks for the pics .. Let me know how much shipped to 89015 thanks Rick
Rick, I'm going out there in a bit I'll get you a total. Thanks Randy
fishyalien, $30 plus shipping for hinges and these parts. Thanks Randy
Payment sent via paypal for linkage brkt and clamp, and PM sent with shipping address.
Thanks, Mark |
Payment made to you for the gun racks. PM sent too. Thanks, Dan
Thanks Dan and Mark, I should be able to get your parts in mail this week, Randy
4 Attachment(s)
pics of 67-68 steering column, the indicator has a washer under screw and the wiring has been spliced, no shifter but could throw in a 69-72 style, $40 plus shipping
BCNYA2, Greg, in post 115 4th pic there is a pic of a e brake setup with a spring, I have a extra spring out there if this is what your needing
Is the rubber floor mat still available, what condition is it in? apears decent? thanks!
Matt, it is decent but I don't know about folding it up in a box and shipping it, let me try it tomorrow and see. The last one I shipped cost like $30 to ship. Thanks Randy
Justintime67, steering wheel is still for sale $30 plus shipping, it has a bend in it, I tried to get pics but its hard to see. I think it can be straightened when mounted, horn guts come with it. Thanks Randy
Will take the 3 lighter set ups as pictured. Thanks.
Payment sent for seatbelts thanks.
I will take the a/c balls for sure and the rear bed molding send me a PayPal address and a total please to 77505 thanks
Eric, I will get them in the mail
Beaumont@, I will ship out this week blackbolt, I will get a quote Thurs Thanks, Randy |
That's fine Randy, mines' just a driver. I really need one with the top arm in good shape. as long as they mount, im ok with a chip. Pm payment info please |
So you just need the cowl flapper?
Hey teeitup how much for these item
1 chrome cargo light housing 2 clear cargo lens 3 (4) of those thing that goes behind the window and door handles 4 are those cargo light switches in post 23 picture 5 on the right side if so I need one |
Hi Randy - looking for an unbroken set of defroster vents in blue - looked like maybe there was a set in the pics? Thanks, Ben
Randy,
How much shipped to 95492 for the long retention spring and the 2 clips to secure the spring in the picture below? Do you have the spring in the picture? The other springs in the picture look a little rough. I need one that isn't damaged Thanks |
How much for the repair section for radio hole on dash - picture set #80, 4th photo down from top - sent to 65202 zip code?? Thanks, Jay
Randy, thank you for the pictures. I'm amazed you can keep up with this thread. I've added to my list......trying to do my part to keep you doing what you do.
Open Items 1) Med blue glove box door $10 - I see the hinge, is the open support bracket and screws there? 2) Tranny dipstick and tube $5 - that dipstick is not as long as I need. Any longer ones? since 4x4 engines sit further back, I'm wondering if 4x4 are longer 3) 4x4 Shift knobs - Blank or 4x4 pattern - I wasn't sure on your response, have any? 4) Brake booster to intake manifold vacuum hard line - any good ones 5) Powerbeam 3 prong headlights 6) 2x headlight buckets - got a pair not rusted much 7) Any Rochester card studs? 6 1/2" 8) Radio deluxe knobs, mount cups, nuts and dials 9) Shift linkage assembly - steering column attach bolt\nut\washer, main linkage, frame mount with pin, spring, bracket to tranny, clips, washers, tranny bracket - I wonder if a 4x4 with TH350 has a longer linkage because the engine thus tranny sit further back. 10) 6x ground straps - any decent one, various lengths to do one truck 11) Duel horn harness 2x 12) What are the black caps in the gas cap picture #21-4 ? 13) Steering column firewall rubber seal and mount bracket #21-3 14) Steering column - green gear indicator #21-3 15) Radiator shroud clip #24-4......do you have 2? 16) Any AC\Heater core mount brackets?.....I think that is the non straight ones, right? 17) Firewall flapper 18) Engine side and Cab side AC\Heater fiberglass boxes #28-2 - I need a good set with no crack, good grain......mostly engine side as mine is cracked - whatever addition parts you want to throw in......vac ball, etc.. Set Items 1) Greenblack wire with plug $5 - I'll take 2 - $10 2) Radio red wire $5 3) 3 boot rings and boot $25 4) Softray wing windows pair $20 5) 6x 72 door screws $20 6) Short gas filler $20 7) Air cleaner wing nut 8) Coiled oil pressure line $10 9) Pulley $8 10) 2x T-3 three prong bulbs $20 11) E-brake pedal setup $10 12) Kick panel vent I know I have pass side for AC and drivers $15 - I'll take 2 sets if you can come up with another good pair - $30 13) Blazer front to rear wiring harness $5 Thanks Jim |
randy, great job on your valentines special! payment sent for my parts. I will take a nice pair of door edge guards. when you get a chance get me a price thanks jim
Thanks, Daren |
Randy, I'll speak for the toolbox. Trevor
