120 good compression?
I have 71 Chevy 350/350. I did a compression test I got 120 on all the clynder. So is that good or bad? Mileage is 147,000.
Posted via Mobile Device |
Re: 120 good compression?
I just did one on a mopar motor last week, came up 130 psi through all cyl, ended up being the guage. like said above, more than 10% is what your looking for.
I wouldnt be worried about it with an old motor sounds like its in descent shape, and definetely a good thing that there all even.
Nothing wrong with engine other than oil leaks. Which I plan replacing the gaskets this spring.
By the way asahi how did you get the name? Is it the beer? They make fantastic stuff.
It was the name of our beloved Akita. Asahi means morning sun in Japanese. Akita's are excellent protectors and great family dogs. Our Asahi is greatly missed.
Akitas are indeed great dogs. My Lab is 12 and I dread the day..........well you know.
Anyways, you never answered if you did the compression test with the throttle blocked open or not? (ignition disabled) |
Sorry throttle was closed
do it with the throttle open and it should be higher
Someone (HEI?) had a good idea about disabling the ignition, which is a good idea anyway, but more so that you don't forget, put it all back together, and then fire it with the throttle blocked open to WOT. I'm sure we've all been down the "There's no way I'd forget X" highway. |
Sorry about your loss. Im sure we all wish they could live much longer. I have two 13 year old goldens. Akitas are awesome dogs.
