Body lines
3 Attachment(s)
Not sure how bed is supposed to match up with cab. What I have now. I do not have the little rubber straps between bed and frame. There are new cab mounts.
Forgive the smeared on bondo I never got back to filing down. The top of fender is close to the line on back of cab but the bottom molding line looks way off from molding line of cab. Thanks |
Re: Body lines
Looks like your bed is way high..is it repop parts?..
I would get the bodyline in pic #2 lined up and see what it looks like..some pics taken from further away might help |
Re: Body lines
Bed floor is original bedside are repops. I just saw another thread with a guy with the same problem but didn't see a resolution.
Re: Body lines
Take a pic of the gap between cab and bed , that shows it from the bottom of bed to the top of bed rail
Re: Body lines
2 Attachment(s)
The top of blue tape is at top of "breakover" on each. Appears to be a 1/2-3/4 inch difference. Uploaded photos twice,not sure why they are sideways. Sorry
Re: Body lines
2 Attachment(s)
Looks like the cab needs to come up
The door looks low as well |
Re: Body lines
Door is cracked open a little so that may look like it. I don't see how the bed can go down,so I guess cab needs to come up. Just trying to figure out why. Maybe the repop fenders are off?
Re: Body lines
It could be the bedside... repop stuff is well known to be bad , even when new..
But even when looking at the lower rocker to bottom of bedside, the cab still looks low Is the cab sitting level on the frame? |
Re: Body lines
What is the truck? C10, C20, K10 or K20? Where did new cab mounts come from? Can you post a pic of the rear cab mounts?
Re: Body lines
Sorry. C10. Was my dad's since new so I know the history. New cab mounts came from lmc truck. Rubber,and installed per the diagram. I'll try to get a pic ofthem in a bit.
Re: Body lines
Here's the pic of rear cab mount.
Re: Body lines
sets low in the first pics. They are LMC rubbers. The newer ones purchased from a forum vender sit much higher. Granted my truck is a 4x4. Maybe something to think about? |
Re: Body lines
Thanks. I'll check it.
