Automatic tilt steering column
5 Attachment(s)
This is now a truck tilt steering column converted from a van column. The neutral safety switch was moved to the correct place on the column & the hole where it was is filled back in & it has the correct length splined shaft to make it truck tilt column. The column was cleaned & stripped, then painted semi-gloss black. It was checked for worn or broken parts & replaced if necessary. Bearings & pivots have been greased. The following parts are new, turnsignal switch & wiring harness with correct horse shoe wire connector, indicator housing & lense, indicator pointer, warning flasher knob, neutral safety switch, upper & lower rubber seals with correct firewall retainer, turn signal & tilt levers, shift lever is used but in good condition, if you want a new one add $35.00 dollars. Horn contact cancel cam & spring also included. $ 445.00 Shipped / Shipping to U.S. only. No Shipping to Alaska or Hawaii / Postal Money Order or Personal Checks
Posted via Mobile Device |
Re: Automatic tilt steering column
I will take it.
PM'n you for payment info. |
Sold to External, PM sent. Thanks
Alright. My new steering column is installed and I could not be more happy! The packaging was superb and there was no way any damage could have occurred. Product was exactly as described. Super thrilled to have made this purchase! I would purchase anything from Don without worry. 10/10 would recommend to a friend. First time sending a check to someone I don't know off the internet, all fears are gone! Again, I would purchase anything from Don. Thank you so much!
