Why do I constantly have to log-in?
For the past year or so, every time I come to the site I have to log-in. For example, today the site has probably logged me out 4-5 times. Checking "Remember Me" doesn't help. Is there some way I can stay-logged-in?
Thanks. |
Re: Why do I constantly have to log-in?
What device are you using? Thats more of a curious q
Look at this thread and see if it helps at all http://67-72chevytrucks.com/vboard/s...d.php?t=830630 |
In other news that link should be https. My phone chanes it to http which in turn logs me out
I have been having this same problem for 2-3 years now. I finally figured out that it had to do with either being on the http (normal) or https (secure) version of the site. Once I told my browser to always use the https (secure) version of the site, I have not had to re-login to the site, unless I specifically log out.
As a side note, my iphone acts stupid with the http (normal) version of the site. For instance, I do a Google search for truck stuff and it happens to pull up results from this site, they are always the http (normal) version of the site. If I follow the link, it doesn't recognize me as a member and none of the attached images show in the thread. If I change the http to https in the address bar, everything is fine. I even changed my signature to the https version so if I click on it on my phone it takes me to the secure version an doesn't log me out. |
I changed the shortcut url to https. Problem solved!
