removing old seam sealer
can someone tell me how to remove the old seam sealer..Thanks Ronnie
Re: removing old seam sealer
hey red in the summer ill be doing mine over also and considered using a heat gun but would like to hear what others have used before i try it for fear of lifting the paint, perhaps a chisel will work and heat gun the remains ?
It will almost definitely lift the paint because it should be UNDER the paint ... i used a wire brush on a cordless drill.
I used a wire wheel on a electric grinder. It cleaned it out fast. But I was not worring about protecting the paint.
Propane torch will burn it out too.
I just did this last weekend on my '66. I used a screw driver as a chisel and just tapped it along; knocked all the stuff right out. Hit it with a wire wheel and looked pretty good.
Screwdriver then wire wheel here also.
I used a stiff gasket remover knife and went along the edge of the vertical lip and "cut" it free from that edge. Then I came in flush with the roof panel and basically cut it out in large chuncks. After I got most of it out, I came back in with a twisted wire wheel disc (not the cup style) and removed the left over. Make sure you have a full face shield when doing this. Overall wasn't very hard or time consuming... unlike stripping the old paint off. :(
3M makes a paint and rust stripper wheel; sort of looks like a Scotch Brite pad on steroids. They sell for about $6 each at most paint/body/auto stores. I use it in a drill and have had good luck with seam sealer, paint, rust, undercoating... Watch the direction you spin the drill compared to a metal edge or you will shred the wheel quickly.
wire wheel and an angle grinder works fabulous...........
ya what he said....OUCH!!! but they are worth the money they will cut you time in half !!
