bags not holding air all night..is it the PTC parts?
ok so i just put a set of bags in the rear of my truck with shrader valves and PTC fittings..is there a better way to do this? what should i be useing,and yes i put sealent on all the threads going to check where the leak is with soap and water...are the PTC joints bad? what do you guys use?
Re: bags not holding air all night..is it the PTC parts?
I like to put a little simple green and water in a bottle, spray it on and watch the bubbles. Sometimes you just need to tug a little harder on the PTC or re-cut the line.
no i didnt cut the lines clean and square...whats best to use a razor?
lol so funny that has to be it thanx again...
a good clean fresh razor will make the cut very clean
this site is great you guys know lots about everything thanx for all the help i know that i post lots but i have a lot of questions.. and i need answers...thanx
These work great.
http://compare.ebay.com/like/2202800...Types&var=sbar |
ooohhh yes i want one ...
Yeah the tubing cutter is a life saver.
I know your going to say why is he telling me this, but be freakin careful when cutting line with a razor. It should be supported on a hard surface, if you want to cut just the line and not your fingers. Not that I have ever done anything dumb like that, just sayin....;)
so i used a razor and the one side is all fixed but i cant seem to get the other side right..and yes my fittings are DOT.
is loctite 596 the right sealent the right stuff ?
Loctite 545 is what I use.
It's pneumatic/hydraulic thread sealant. |
dope thanx man.
