i need some recomendations
i have a 90 suburban and looking to drop it approxiamately 4/5 inches in the front and 6/7 in the rear what do you suggest i use?
Posted via Mobile Device |
Re: i need some recomendations
Front 3inch drop spindle and 2 inch drop spring or 2 1/2 spindle and 2 1/2 drop spring. Rear 4 inch drop hanger and remove a leaf spring or two. As well as a bolt in c notch
What website can I order those hangers and drop spindles. This is my first project that I'm doing the suspension on
i havent had any luck in finding hangers that would lower it that low what about a flip kit?
Drop hangers and shackles together will get your 4 inches. To get 6 you can do a flip kit. To get 7 you can do a flip kit and shackle.
Do you have a link where I can order them from
A truck flip kit will get you in your 6"-7" rear drop range,... but you will need a c-notch and sheetmetal mod to the floor to keep the center section of the rearend off the floor.
My old '91 burb had 4" drop leaf springs and the rearend was close to hitting on large bumps. |
As for the hangers I have no clue |
I had shackle/hanger drop on my mind. Sorry. If you do a flip kit,... stick with Belltech or Western Chassis or McGaughy's. They have a better designed flip kit bracket. |
thanks i seen a belltech set up on autoanything im gonna probably go with and its a 4/6
my 90 burb had the belltech spindals , cut coils , flip kit with helper bags
and sat nice and drove great , will do the same with my next one Posted via Mobile Device |
Did you change out the shocks also?
I ram some stock Replacement kybs
