age old question
What are the best aftermarket BBC engine stands to buy, I am really thinking about converting over to a BBC, Mark Jones aka vortec pro has some really decent prices on his 468 BBC engine and i have not heard one bad thing about his builds so far
http://www.vortecproperformance.com/...binations.html |
Re: age old question
can you use a short water pump on a BBC and will a TH350 tranny bolt up to the engine?
i was wondering if my pulleys would swap over to a BBC, if i kept the short water pump |
All trucks '72 and earlier had short water pumps whether a small block or big block. The pulleys nor the accessory brackets interchange between small and big blocks. With a short water pump on a big block you will need pulleys and accessory brackets specifically for a big block with the short pump. Yes a TH350 will bolt up to a big block, but it will need to be built to handle the increased torque.
