-69 C20 Brake Conversion help
I guess there are several threads in this subjekt and alot of people who have dont it, but I just need help with some info:
What year will fit my truck and what is best to look for? How much (parts included) do I need to change? Is there any tricks or things you need to think about doing this? Perhaps someone can link another thread from the forum. Many thanks Pete |
Re: -69 C20 Brake Conversion help
HI Pete,
I replaced my complete frontmember with one of a '73 model. It'll fit right under, but you will have to redrill 2 holes on each side. you'll see pictures in my own thread linked in my signature. |
What rearend to you have? Eaton full floater? you can use the 14 bolt conversion brackets, The hubs off of the eaton, the calipers and front rotors off the front of a 72 work fine. You will need a Disk/Disk proportioning valve to replace the Drum /Drum unit.
Front conversion i don't have info for. |
Thank you for the info... and swamp rat, i will start with the front and then figure out if I want to go back also!
I have been reading alot about drum to disc swap in the forum, and I found this in one thread: All of these are good sources. 71-87 trucks. 71-91 suburbans. 71-82 2wd blazers. This was for a C10 truck.. but will it be the same years for a C20? I also found this on Ebay: http://www.ebay.com/itm/271089197023...%3AMEBIDX%3AIT Must be a good deal... |
I have a complete 72 crossmember (disc brakes)with power booster, master cylinder, and proportionong valve for a complete swap over that gives you front disc brakes! Feel free to contact me here and or via text/call. Adam 951-544-0721. And I am in Riverside, local to you.
