Which bolt does the clip on the purple starter wire go on?
Wasn't sure where to put this one. It isn't really an electrical question, it's more of a restoration question. If a mod feels it should be moved that's OK with me.
I am running a new purple wire to my starter. I pulled a wire off a donor truck but it's melted and not usable, but I am going to take the clip off this wire and would like to put it back on the engine where it goes. Is it one of the bell housing bolts? |
Re: Which bolt does the clip on the purple starter wire go on?
yes ,,, not the top one/ middle one but the one on the pasenger side next to it
So of the two on the far right (passenger) it would be the top one correct?
Yup. Personally I always go with the solenoid approach, that way I can bump the engine if I need to while working on it
that bolts to the trans to engine mount bolt closer to the starter. bell housing bolt
