Transmission Swap
This is my first question of many to come
I bought my son a 56 GMC that needs a lot of work, I got a 350/350 transmission I'm installing with an under cab power brake booster. What crossmember should I use, and will I have clearance issue.t |
Re: Transmission Swap
I'd believe that a bit of searching will find you a pretty much bolt in crossmember designed for that application for well under 100.00
Most of them are going to look quite similar to this one that popped up on a quick search http://www.ebay.com/itm/NEW-TUBULAR-...item3f4eee25e2 Most likely you can pop into your local O'Reilly store with a speed center and order one for close to the same price and have it on the next truck shipment if they don't have one in stock. |
