1953 4400 1 ton dualy (flat bed)
Can I put a period bed on this flat bed?
Re: 1953 4400 1 ton dualy (flat bed)
Well... a 4400 is a 1 1/2 ton ..not a 1 ton..but if you don't have a bed it may be hard to find what is period correct..most of the (correct) ones I've seen have a steel band around the bed that resembles the front bumper in shape..it has the same ridge design to to it..like in this pic
This appears to be the same truck.
https://pbs.twimg.com/media/Ci_c7k3UUAA96Ny.jpg:large It appears that the steel band around the bed is stock... |
Yep..same truck..its been all over the net for sale for awhile now..
You could put a pickup bed on your truck..the cabs are identical on all the ad trucks except for the coe..the front fenders on the 1 1/2 and 2 ton are longer and wider than a half thru 1 ton truck though..check out lower 50s build.http://67-72chevytrucks.com/vboard/s...d.php?t=648459
A correct period bed on the 4400 would be the bed with the ribs around it that Mongocanfly showed in post 2.
We have a 51 4400 out back that my daughter wants to build and put one of those beds with a hoist on it. The hoist because the truck that belonged to a friend of mine when she was little had a hoist and she always thought it was a really cool truck. Cost may eliminate that and we will just go for a nice flatbed with some nice stake racks. You could put a box on it with fenders if you can find one of he long long 1 ton boxes in reasonable shape or build your own and widen the fenders quite a bit. There is no pickup bed/box that you can just set on the frame and bolt it down and be done though. |
