Drop spindle differences by brand?
Hi all,
86' C10 stock 15X8 rally, Looking at 2.5" drop spindles (1" rotor) but most searches come up with 67-72 trucks. I have seen posts that say drop spindles push out the wheel a little, is this just on 67-72 or all? If this is the case, what brand will move them the least? I emailed CPP but they told me they don't manufacture spindles for the 1" rotor. I found Western Chassis spindles for 1" rotors on Summit, but at the moment the price is $603, no thanks! I have an email in to see if this is a typo. Any other suggestion I should look at that won't affect the track width? Thanks for any input. |
Re: Drop spindle differences by brand?
cpp does not make spindles for 1" rotors only 1.25.
western chassis spindles are not $600 from summit I think I paid around $260 when I bought mine. all spindles will push the wheels out. also western chassis spindles will not cause the wheel to rub on the lower control arm....all other spindles will cause the wheel to rub on the lower control arm an you will have to grind on the control arm for it not too. |
Wow that must be a typo but I also see the 600 dollar price tag as well as the shipping date of next month. Someone else on the forum was talking about them being backordered. Might try calling western chassis and buying direct for 260.
We need an ask all tell all sticky'd drop spindle thread on here:lol: |
well I know it depends on what size and backspacing is...smh I was just letting him know that he will not have that problem with STOCK 15X8 RALLYS WHICH HE CLEARLY SAID HE HAS. thanks
Summit has the WC spindles for $235.97 with free shipping, but they're on backorder.
Keep in mind that Summit now charges tax on Texas, so be sure to figure that into your shopping equation. |
Thanks for replying all. I should have stated I have stock upper and CPP lower control arms. I just looked again and the WC spindles I need still say $603 lol. How are the McGaughy's?
I used DJM 3" drop spindles on my 87 with the 1" rotors and I did not have to grind the control arms. I'm running 15x8 Rally wheels.
Posted via Mobile Device |
Brothers has Western spindles for $269.99 in their catalog.
Thanks again all,
Since my brakes are starting to bounce, I was thinking of just upgrading to the 1 1/4" brakes. I can get WC brake kit and spindles for $578, seems like a good price. It is weird, the brakes are not shimmying like they are warped, just bouncing when I press hard when I have to slow down fast. |
To compare apples to apples you have to have the wheel info when you are talking spindles and the wheel rubbing the lower a-arm. All of this has been discussed to death on this forum. |
Not false so you might want to get your info right. Thanks☺
