Dash harness routing
I purchased a new dash harness for my truck from America Autowire and it appears to be to short. It lacks about 3 inches from connecting to the ignition switch. Or atleast I think it does! I've tried every way possible to route it. Does anyone happen to have a pic underneath the dash of how it is supposed to be?
This truck I'm building from scratch and really dont have any references on how anything was! |
Re: Dash harness routing
Or is there some sort of extension/pigtail that goes to it?
Can you post a pic without the gauge panel installed?
Yes. I will take one this evening when I get home from work. |
Here is the pic
I used the AAW setup. I had no problems with any of the wires being short. I have no complaints about their products or customer service. I did the whole setup, maybe that makes a difference. Call them, they were always super helpful for me.
RR |
The wires run above the brake pedal bracket I think. Looks like your running yours below.
Try routing the harness over, in lieu of under, your steering column. I believe you have the harness routed wrong.
