504 1969 Yellow green Metallica
Does anyone have the formula or did anyone paint a truck
504 1969 Yellow Green Metallic? Using Urathane base with a clear coat. No one seems to be able to mix it, I gave them my ashtray, and glovebox door But it is faded and the yellow is not as pronounced as the paint behind the gas tank, inside the engine compartment on the fenders or firewall. Thanks for your time Trip |
Re: 504 1969 Yellow green Metallica
if the truck is drivable , you can go to the paint store..they can use a handheld spectrum analyzer and match the truck ...maybe when the coronas blow over
You don't need the formula because you have the code... 504
Ask around your local paint stores to see if they can mix it. Regardless of brand, some if not most will be able to make the color. http://67-72chevytrucks.com/vboard/s....php?p=8597082 |
Thanks so much for the paint chip!
I will bring this to them, thanks guys! Trip |
am I the only fool who came here to see something Metallica related ??? lol
