Unfused HEI wire?
I noticed that my HEI wire is plugged into the unfused terminal on the fuse block.
Should I install an inline fuse, if so what size. Thanks K.E.N. |
Re: Unfused HEI wire?
That's what I did with mine. It didn't feel right going without a fuse.
Here's the one I used, but I see it's not available now: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 The might be good, too: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 |
I have never done a fuse on that ......Ask you a? , did you see the factory fuse that hei? If you understand, why would you worry about a fuse on the ign system? Longhorn:smoke:
Does not have voltage with the key off . You are Golden.:metal: Less is More;) |
Hello,I didn't know that terminal lost power with the key.
Thanks K.E.N. |
On my '70 there were two of those extra unused unfused terminals. I used one for the HEI and one for the electric choke on my Holley.
I put an inline fuse in mine. I remember going bigger than necessary, maybe 10A, so it will never blow under normal use unless it shorts.
Thanks All I will install a 20amp in line.
K.E.N. |
