70' Blazer 4WD (Wire ID)
2 Attachment(s)
I have this wire lead that i don't know where it goes. i don't see it on the wiring diagram. It looks pink to me. Maybe for an accessory?
It may not be from this truck. Any help appreciated. thanks. |
Re: 70' Blazer 4WD (Wire ID)
Hello and welcome to the board.
That wire could be for an accessory, I don't recognize the connector as anything stock. |
Yes the transmission controlled spark wiring harness, I forgot about the 70 and 71s. Also the carb idle solenoid has a red wire going to it to hold the idle up if the AC is on.
Wondering if that wire number 141 in the diagram is the brown wire in my harness? otherwise, not sure what it is.
It might be a TH400 transmission kickdown wire. That grommet on the wire would pop into a hole in the firewall.
https://67-72chevytrucks.com/vboard/...d.php?t=811030 |
