after market signal lights
Hi was wondering if someone can help me with wiring for a signal stat 900. I looked on the web and found the wiring diagram for a 7 wire, but for some reason mine has 10 wires and cant find any thing for those. dont no what the other 3 wires do Thanks Denis
Re: after market signal lights
I was thinking that your extra wires might be for the left and right turn signal light wires in the dash. Or maybe even for the front marker/turn signal lights.
Do a continuity check between them and the left and right turn lights in the signal stat switch. |
Found this on the truck lite site. Think they own signal stat now. https://www.truck-lite.com/915y124.html A 10 wire for Peterbuilt trucks. Extra wires appear to be for high/low beam on the unit linked. Sorry no signs of a wiring diagram I have found. Maybe email truck lite and ask for one?
This is the only thing I found in the link below.
It breaks down the wiring into 3 categories. 1-Turn signals 2- Flashers (If it has the pull-out flasher bar) 3- Bright and dim lights (If it has the button on the end of the lever) Hope this helps. http://www.forum.aths.org/Attachment11161.aspx |
Richard and Getter Done thanks for the info but the lever only moves up and down and no button on the end of lever. Don t need them i quess won't worry about it
