Old 07-19-2015, 08:29 AM   #1
Lambchop76
Brake/turn signal issue
I have an 87 Silverado R10 and my left rear blinker and brake light no longer work. I replaced the bulbs and sockets with the LED conversion from LMC a year ago. Everything worked great up until 2 weeks ago. I have chased and stabbed wires with a test light all the way to the column and there doesn't seem to be power to the yellow wire for that light. Could my problem be in the column in the signal switch? The left front blinker works fine though. I am completely stumped and aggravated. Any insight is greatly appreciated
Lambchop76 is offline   Reply With Quote
Old 07-19-2015, 08:59 AM   #2
J Knight
J Knight's Avatar
Re: Brake/turn signal issue
If you cant get power past the signal switch my guess would be a bad signal switch also.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 07-19-2015, 10:28 AM   #3
JacobSchni
JacobSchni's Avatar
check for a good ground on the bed and the bed to frame
JacobSchni is offline   Reply With Quote
Old 07-19-2015, 10:43 AM   #4
Lambchop76
Would that cause the lack of power to that yellow wire under the dash?
Old 07-19-2015, 11:46 AM   #5
Titomars
Titomars's Avatar
Nope.
If you have no power from the yellow wire at the T/S switch harness connector the switch has failed or the wire running up the column is broken between the connector and the switch itself. Personally I would just replace the switch since it has to come out to inspect it anyway.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 07-19-2015, 01:34 PM   #6
Lambchop76
Originally Posted by Titomars View Post
Nope.
Ok that's what I was thinking. I replaced the steering wheel with one from a 62 bel air, and the canceling mechanism was not compatible with the older wheel. So I removed it and just have to manually cancel the blinkers. I thought that may have something to do with the switch failing
brake light, switch, turn signal
