Old 11-28-2022, 07:19 PM   #1
SOON2BLAZE
SOON2BLAZE's Avatar
Gas gauge to 90 ohms
With the installation of a Camaro tank and the 90-ohm sender, it seems that the quickest solution to convert the 30-ohm gauge is a 90-ohm resistor.
Pic 1: 1966 warning cluster gauge gas gauge (not mine)
Pic 2: the 90-ohm resistor
Plan: Remove the 30-ohm shunt and harness tangs, add the 90-ohm shunt and plug the harness back in. I may add an additional ground. Thoughts?
SOON2BLAZE is offline   Reply With Quote
Old 11-28-2022, 07:45 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Gas gauge to 90 ohms
Can't wait to see if it works.
Old 11-29-2022, 05:38 PM   #3
Ken Cook
Ken Cook's Avatar
Call John at Redling Gauge Repair. He can tell you how to make it work. 731-571-0766
https://www.redlineg.com/contact
He changed my AMP Gauge into a Volt Meter and also calibrated my Temp Sending Unit to my Temp Gauge.
Good Luck
Ken Cook is offline   Reply With Quote
Old 11-30-2022, 07:46 AM   #4
The Rocknrod
Moderator
Run some test leads to/from the sender, it'd be easy to find out.
Old 11-30-2022, 11:04 AM   #5
sirJim
You might want to look at this wright up.
http://67-72chevytrucks.com/vboard/s...d.php?t=447185
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 11-30-2022, 11:12 AM   #6
SOON2BLAZE
SOON2BLAZE's Avatar
This is the plan. Thanks for all the responses. I read through as many old posts as I could. It appears electrical is right up there with voodoo
