Old 06-08-2008, 11:12 PM   #1
19gmc67
19gmc67's Avatar
project nightmare
here is my 1967 GMC i just started work on .its been a nightmare from the start,every time i start working on it the weather gets bad.i had it running,but now i have nothing.wont start....any advice?well without ferther delay here are the pocs of project nightmare
here are pics of the rigged sunroof[not my doings]
19gmc67 is offline   Reply With Quote
Old 06-08-2008, 11:20 PM   #2
19gmc67
19gmc67's Avatar
Re: project nightmare
more pics
motor is a olds 350
here is the vin number,can anyone tell me about this truck
Old 06-09-2008, 04:52 PM   #3
berencam
berencam's Avatar
wow... looks like you have alot of work ahead of you. good luck piecing that one back together.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 06-09-2008, 07:47 PM   #4
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Wow, looks like the '80's grabbed ahold of that thing and won't let go. As far as starting goes, start with basics: Air, Fuel, Compresion. Obviously, your getting air. I would check for spark first. With an HEI, the ignition modules are known to go south. I'd almost be willing to bet that's what it is. How long has it sat?
It's cool to see a Rocket in there. Those are real good motors. Had a couple myself. Torque MONSTERS!
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 06-09-2008, 10:56 PM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
I decipher your Vin as the following
C=2wd
S = inline 6 cylinder
1= 1/2 ton
57 = 115' wheelbase (shortbed)
0D = 67-69 fleetside
good luck with your build.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-09-2008, 11:16 PM   #6
19gmc67
19gmc67's Avatar
the hei is new ,im getting no power.no lights or anything.thanks for the suport.
Old 06-09-2008, 11:46 PM   #7
dieselarmy13
After looking over your pics again, I seen the pic of your fuse box. All that needs to be sorted out. One thing to keep in mind with automotive wiring is grounds, grounds, and grounds. And then go back and check your grounds. A little off the subject, but I once had a 2004 Frieghtliner in because it was completely dead. No nothing. Turned out to be a bad fog light switch that was grounding out. No kidding. Good luck with your project. I'll be watching.
Old 06-12-2008, 03:08 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Good luck with the build!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-12-2008, 04:10 PM   #9
68 short step
get to work
68 short step is offline   Reply With Quote
Old 06-13-2008, 12:24 AM   #10
19gmc67
19gmc67's Avatar
going to the junk yard this weekend to look for parts.wish me luck
Old 06-29-2008, 11:41 PM   #11
19gmc67
19gmc67's Avatar
started back on the truck today,found a newer driver side door for the truck .got it on the truck but it not wanting to line up.will post pics 2morrow.yall will like the paint jod the door has.also going to order a ez wiring get this week.
