07-04-2023, 08:08 PM | #1 |
1965 c10 12 bolt axle bearing removal
What is a good way to remove old axle bearings from my 12 bolt under my 65 chevy 10? I tried my dent puller with an attachment but did not work. I also tried heating it still did not move. Any ideas?
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
07-04-2023, 08:30 PM | #2 |
Re: 1965 c10 12 bolt axle bearing removal
takes a pretty good hit with a slide hammer to get them out. just did them in the 71 this afternoon. but I used an axle puller slide hammer kit.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
07-05-2023, 11:08 AM | #3 |
I used a slide hammer for mine as well. Made quick work of them. You should be able to rent the kit from your local chain auto parts store
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
07-05-2023, 05:05 PM | #4 |
Ok thanks
07-05-2023, 11:01 PM | #5 |
Ok so after trying the dent puller again I gave up and pulled the carrier again and ran a long pipe in the axle tube and drove the bearings out Now all back together with new bearings and seals.
07-06-2023, 11:25 AM | #6 |
That's exactly what I do when I get a stubborn one. Have a 6' piece of sacrificial 1/2'' galvanized pipe for the task. I use it more often that not.
