04-10-2004, 02:08 PM | #1 |
Hatch Hinges
Has anyone rebuilt the hinges on their Hatch?
Do they make a kit or do you have to questimate what the bushing sizes are |
04-10-2004, 04:17 PM | #2 |
I am just working on rebuilding mine using carriage bolts that are filled down. I am having a hard time finding the nylon bushings though.
04-10-2004, 04:45 PM | #3 |
Someone on ebay I thought had a set for sale that they said had just been rebuilt. It was a board member. I got so busy I never got a chance to contact them
04-11-2004, 01:09 AM | #4 |
Gee Emm
You can by some nylon or teflon stock and machine it down to size. It machines beautifully. Comes in handy for a soft face punch as well.
Toys: 72 K5 Blazer 74 Vette |
04-25-2004, 12:44 PM | #5 |
hatch hinges rebuild
Hey Guys,
I just re-built mine. I bought some bronze door bushings and drilled the one hinge that they go in. Drilling the hole a little bigger by stepping up in drill size little by little untill the bushings fit in the hole snuggly by tapping them in with a hammer.On the other half of the hinge i ground down just a little bit of metal off of each side untill the 1st half fits in.I gave it a little play. The bronze bushings have a little thicker rim .By using the bronze bushings the hatch will outlast the plastic ones. The bushings i used looked like a side door bushing but with a little thicker sides and they had grooves on the side of them.I think the pin that holds the 2 together are still available from the dealer. P.S. the inside diameter of the bushings for GM are somewhat standard in size.same with the pins hope i can help ya out Tom Last edited by earnhardt221; 04-25-2004 at 12:48 PM. |
04-25-2004, 07:47 PM | #6 |
Back in the sticks
Do you just cut the pins to length depending on which hinge you are using them on? Any time I have looked at the rebuild kits, the pins look really long.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
04-25-2004, 08:33 PM | #7 |
I found a set of pins in one of the help rebuild kits at a local parts store. Haven't bought yet no time. I will try and get a part or kit#
04-26-2004, 07:30 AM | #8 |
hinge pin length
The ones i bought from the dealer were the correct length.If you buy a set that are too long just cut them to size but leave them a 1/2 inch long and taper the ends.The ends are tappered so when you hammer them out the ends do not mushroom.The pins i bought from the dealer did not have a rounded head like a rivet.They were flat but still look good.
