02-12-2023, 03:24 AM | #1 |
Gauges in the Heater Switch Panel?
Anyone mount a couple of gauges in the panel where the heater switch is? I've removed the Thrift heater system completely, I'm planning to add a Vintage Air under dash AC/Heater system as soon as the wiring is finished.
This panel looks like the perfect place to mount a Oil Pressure and Water Temperature gauge. Anyone have any pics of an install similar to this? |
02-12-2023, 07:53 AM | #2 |
Moderator
Re: Gauges in the Heater Switch Panel?
I know I've seen em mounted in the heater control panel, just can't find a pic right now.
02-12-2023, 09:58 AM | #3 |
Skinny G did air gauges hidden in the ashtray
https://67-72chevytrucks.com/vboard/...postcount=1105 https://67-72chevytrucks.com/vboard/...d.php?t=756182
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
02-12-2023, 01:21 PM | #4 |
Cool! I was about to post that...
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
02-12-2023, 02:25 PM | #5 |
You may want to decide on your AC controls are going to go before adding gauges to that spot.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
02-12-2023, 05:36 PM | #6 |
I'm pretty sure I'm going to do the Mark V underdash unit from Vintage Air, all the controls should be directly on that unit, but I will confirm. Going for the old school look...
02-12-2023, 06:38 PM | #7 | |
It's Better With Nitro
That's cool! I installed my nitrous arm and purge buttons in my ashtray.
http://youtu.be/vldlvb3fyik Quote:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 02-12-2023 at 06:45 PM. |
02-13-2023, 09:31 PM | #8 |
Here's a guage and temp light with VA controls in the radio delete
02-14-2023, 01:04 PM | #9 |
Great choice on AC. That's the unit I am considering. In that case I think the gauges in the heater control spot looks great. I haven't decided what to put there.
02-15-2023, 07:05 PM | #10 |
02-15-2023, 09:04 PM | #11 |
Thanks, I bought the red LED dummy light from O'Reilly's and the sender for it was a generic 135 degree brass one on Amazon. The sender will sometimes trigger the light when I restart the motor on triple digit days after a brief hot shutdown.
