Old 12-02-2022, 12:51 PM   #1
bestchevyfan
How rare ???????????
How rare is a gauge cluster with a factory tach ??? 1981=1987
bestchevyfan is offline   Reply With Quote
Old 12-02-2022, 01:20 PM   #2
Scott91370
Scott91370's Avatar
Re: How rare ???????????
If you have one I would hold on to it. They are gettng very difficult to find.
I've look at I don't know how many at junk yards and in the wild and have only seen 2-3.
Scott
1982 GMC Sierra
Scott91370 is offline   Reply With Quote
Old 12-02-2022, 01:55 PM   #3
79vette
I used to pull cluster parts from local junkyards to resell on eBay and elsewhere. Out of 70-100 clusters over maybe 3 years I probably got 10 with tachs?
The real finds are the c50/c60 tachs that have the fuel gauge and tach integrated into one unit.
1988 "Crane Truck" C30 - 350, SM465, with a 15' knuckle crane - thread
1986 M1009 - 6.2 Diesel, SM465, 2 speed aux trans, NP205 - thread
1979 Corvette - 350 T5
1977 Jimmy - 350, TH400, NP203
1982 Blazer - 350, 700R4, NP208 - Totalled, now a parts truck
Scratch built 16' flatbed trailer - thread
79vette is offline   Reply With Quote
Old 12-02-2022, 09:05 PM   #4
wazzabie
Is the main wiring harness plug and play for the c50/c60 guage swaps?
wazzabie is offline   Reply With Quote
Old 12-03-2022, 12:38 AM   #5
Pontiac1976
Pontiac1976's Avatar
Yes, the power and coil wire are. But you need the 1). printed circuit board (E-bay) get the right one there one guy selling re-pops. not sure how many he has. 2). Tach cluster backing plate (LMC) for the year options you're working on.
Now the Tach with small gas gauge at needs to modify to the plastic you can't have warning light at the bottom of the Tach. for the gas gauge wire terrals.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 12-03-2022, 11:01 PM   #6
79vette
Honestly I dont remember, but I dont think so. Pretty sure the non-tach trucks dont have a tach signal wire in the harness so you need to run one. I'm sure someone will correct me if I am wrong on that though.
But you can remove the pins from the connector on the truck harness and re-pin it to match whatever cluster you have. It's just a matter of figuring out what wires go where.
Old 12-05-2022, 10:02 AM   #7
MJN
MJN's Avatar
Here is some good info on factory tach clusters.
http://www.73-87.com/7387garage/inte...achometers.htm
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
