07-27-2011, 05:38 PM | #1 |
Rear Coilover
If I was going to put rear coil overs in where do I put them. Ie. Do I put them as close to the trailing arms as possible or do I put them near the center section. Thanks guys
1970 Chevy C10 shortbox- 454 1970 Chevy Nova- 383 1987 Grand National |
07-28-2011, 08:25 AM | #2 |
Re: Rear Coilover
I would put them out towards the frame. How much is the truck lowered? To get the truck real low you have to put a crossmember above the bed floor.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
07-28-2011, 11:27 PM | #3 |
60-66 Nut
Re: Rear Coilover
The closer to the wheels you can get them, the better they will do their job. Also as close to verticle as possible.
07-31-2011, 11:58 AM | #4 |
THE DAMN YANKEE
Re: Rear Coilover
i raised the floor of my bed 4" with 2"x4" box tubing, that way i won't have a box across the bed from tub to tub. i agree with DJ Racer on your shock location, as wide as possible. pro street/ drag vertical street "G" machine type 10 degree slant top inward toward center. good luck phipp
07-31-2011, 08:58 PM | #5 |
Re: Rear Coilover
I want to lower the truck 6" in the rear. I'm not sure what spring rate I should be running? I have the fuel cell and the battery in the back of the frame.
07-31-2011, 10:22 PM | #6 |
Re: Rear Coilover
I don't think you will get that much of a drop without the upper crossmember being above the bed floor. The spring rate would depend on the Weight of the rear of the truck.
08-12-2011, 07:45 PM | #7 |
"Where were you in '62?"
Re: Rear Coilover
Competition Engineering Rear Coil Over Shock Kit - 250lb springs included
More pictures here of the whole entire fabrication: http://67-72chevytrucks.com/vboard/s...d.php?t=321173
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
08-12-2011, 08:09 PM | #8 |
~Rest In Peace~
Re: Rear Coilover
alston engineering 4 link with varishock adjustable coilovers
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
08-12-2011, 11:58 PM | #9 | |
Re: Rear Coilover
This setup looks like it would allow the truck to be as low as possible with a coil over shock. I plan to do this to Jr's truck as soon as possible. I just have to get his 9 inch shortened first. I also need a different bracket for the Disc Brake setup.
08-13-2011, 12:27 AM | #10 |
Re: Rear Coilover
Yep.....
As soon as the bed is done and put back on I have to adjust the springs. http://www.jegs.com/i/Competition+En...051K7/10002/-1
08-13-2011, 12:35 AM | #11 |
Re: Rear Coilover
I went on the other side of the frame to get the spring as far out as I could and I still got a six inch drop and I still have about three inch travel on the shocks.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
08-13-2011, 12:42 AM | #12 |
Re: Rear Coilover
Mike What brand of trailing arms are those?
08-13-2011, 12:49 AM | #13 |
Re: Rear Coilover
Those are Mike Bradbury brand trailing arms.
08-13-2011, 01:45 PM | #14 |
Re: Rear Coilover
Sweet. What ya got in making them?
08-13-2011, 01:57 PM | #15 |
Registered Truck Offender
Re: Rear Coilover
He does nice work,, I can tell by looking
Seriously,, thats some very nice fab work on that suspension!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
08-14-2011, 01:37 AM | #16 |
Re: Rear Coil over
Ha, well that would require me to open the drawer with all the receipts and start calculating costs on this truck. I might be shocked at what I find so I will just say that I did not save anything by making them myself, just the satisfaction of knowing that I built it.
They are made from 2 inch DOM tubing .250 wall. I bought the tubing and cut it to length and welded a polly bushing on one end, then they sat in my garage for about 6 months while I worked on other parts of the truck. I was taking design aspects from CPP's trailing arms but was not happy with the polly bushings on the one end. Nate at Porter built told me about his choice of rod ends for his version of truck arms which are the Sphon spherical rod end and they make all the difference in articulation. No binding, and it is not going to get sloppy over time. Since I was building my own custom 9" rear I was able to weld the brackets in such a way that I did not need to bend the trailing arms and could run them straight back to the axle which gives it a sleek uncomplicated look. In hind sight I should have made the perches a bit taller on the arms because I had to end up putting a lowering block in to get the 6" drop I wanted. The pan hard bar is not as flat as I wanted but I made it extra long so I do not think it is going to be that much of a big deal on any side to side movement. I designed system with Bilsteins coil overs in mind and had to go through a couple geometry and spring changes to get it just right. I know I am not going to be winning any auto crosses with the truck but it sure was fun to build. And thanks for the compliments!
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 08-14-2011 at 01:45 AM. |
