Old 09-20-2020, 02:51 PM   #1
clay68c10
clay68c10's Avatar
Tilt column "truck clone"
$475 local for now. I may ship later if I can find good thick-wall tube.
Please respond in thread only per board rules, first "I'll take it" gets it.
Selling a painted and converted motorhome tilt column. From a mid 80s GM chassis
It has the straight shifter arm like a truck tilt
Also has the metal gear indicator and L1/L2 script lens like a truck tilt
I moved the NSS down so it's a bolt-in for your 67-72; I used my multi-meter to adjust it, you may need to fine tune it after install.
Turn signal and tilt levers are new from GMC Pauls
New GMC Paul's gear indicator
Turn signal switch is new
Good used cancel cam
The gray illumination wire is long
Includes a long pigtail for the Neutral Safety/Reverse switch
Tilt mechanism is tight and smooth.
The 4 bolts in the tilt mechanism that typically loosen over time have been removed and reinstalled with lock-tight.
Tilt pivots were cleaned and lubed when removed to tighten the bolts.
The bottom bearing was cleaned and greased
The upper bearings were cleaned and greased
The shift indicator bulb was replaced and tested OK, it has the green shade on it.
Shifter lever end (inside column) is good, pivot is good
Shift arm has nice chrome, it shines up well. There are 2 small ding spots, shown in the pics
The finish on it is base/clear coat gloss black.
The shift arm is metallic silver and includes the rubber bushing and metal sleeve
New firewall and dash gaskets from GMC Pauls
Firewall mount plate included, blasted and painted semi-gloss
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-20-2020, 02:55 PM   #2
clay68c10
clay68c10's Avatar
Re: Tilt column "truck clone"
One more
13 Tahoe LTZ
Old 09-20-2020, 09:11 PM   #3
CarlsLQ9SS
CarlsLQ9SS's Avatar
Very nice!
CarlsLQ9SS is offline   Reply With Quote
Old 09-20-2020, 09:43 PM   #4
clay68c10
clay68c10's Avatar
Thanks! My painter friend did the shiny stuff.
13 Tahoe LTZ
Old 09-21-2020, 12:05 AM   #5
flashed
If you need to ship it , Home Depot sells white plastic pipe with a bell on one end . Pipe has small drain holes along the length but is plenty strong for shipping a column . Cut it to length , slide the column into the big end , the top of the column just fits inside the bell, I taped thin plywood on each end and then wrapped the complete pipe in packing tape .
flashed is offline   Reply With Quote
Old 09-21-2020, 12:23 AM   #6
Curtb1971
Curtb1971's Avatar
Clay, no need for a plastic tube. I'll take it Now I just need to trick you into coming up to the shop Give me a shout tomorrow
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 09-21-2020, 09:21 AM   #7
clay68c10
clay68c10's Avatar
Flashed; thanks for the lead on that. I’ll look into it.
Curt; thanks man. I’ll get ahold of you sometime today.
Sold to Curt
13 Tahoe LTZ
column, tilt, tilt column, tilt wheel
