Old 06-20-2023, 02:16 PM   #1
Getter-Done
Getter-Done's Avatar
Minimum Center Bore size of 14 Bolt FF rear axle
I am looking to have a spare stock set of Tires and Rims for my 84 C-20.
Currently it has 36 x 10.50 x 16.0 Super Swampers on it.
The center bore is 5 1/8" Diameter on these 10" rims.
I want to get a set of rims 6.5 x 16.0 rims.
I know some of the van and 2wd rims will not fit this axle.
What is the (Factory) center bore Diameter,
I need for a 14-bolt full floating rear axle?
I have a Corporate 10 bolt in the front.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 06-20-2023, 04:00 PM   #2
b454rat
Re: Minimum Center Bore size of 14 Bolt FF rear axle
If your getting an aftermarket wheel, don't worry about it, they will fit. Pretty much any 8 lug wheel will fit. Ford/Dodge used bigger hubs than GM, so they will fit. Even 15" will fit lol. Did you have a wheel in mind?
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 06-20-2023, 04:10 PM   #3
Getter-Done
Yeah
This is the closest Example I can find in the link below.
Link: https://www.ebay.com/itm/20415979645...b1b6%7Ciid%3A1
I want this style that will fit over the center housing of the axle bearing hub in the rear.
I could take them off and measure But I am working late for the next few days and thought about going ahead and ordering some that would fit..
84 Chevy K-20
Old 06-20-2023, 10:36 PM   #4
Getter-Done
Update
After the Storm let up here.
I got a jack and tools.
I went back to my Collection.
I dug out one of my spare 14 Bolt rear axles.
I took a (Red neck) measure of 116mm /4.57" on the machined surface of center bore.
My goal here is to get a set of rims that I can run what most people call Street tires on this truck.
I got a Tire shop up the road that will mount the tires.
When I look for Aftermarket rims,
All I see is 8" wide rims.
I am looking for the 6.5 like the stock rims.
I may have to go with the aftermarket 8" wide and a tire to match.
84 Chevy K-20
Old 06-20-2023, 10:39 PM   #5
Getter-Done
I have 2 set of rims and tires that will fit this truck.
Here are the pictures.
84 Chevy K-20
Old 06-21-2023, 05:42 AM   #6
b454rat
Should be able to find some on Craigslist or marketplace. See stockers for sale all the time on either…
