06-13-2002, 11:21 AM | #1 |
My 69 C-10 Pickup
Hey:
I bought a 69 C-10 pickup about 2 weeks ago and I went under the truck to take a look around. Discovered that the truck apparently has had a different rear half welded onto the front half. The doer of this deed cut slices in one of the cross frame members in order to get the driveshaft to fit. I have images of the undercarriage. Could you guys take a look at the pix and tell me what exactly is attached to the front half of the truck. Is the rear half another C-10?... it has leaf springs instead of coil springs! Anyway...ya'll know a lot more about this than I do. Jim M. Here's the links: http://mywebpages.comcast.net/wxgeek/p6100028.jpg http://mywebpages.comcast.net/wxgeek/p6100029.jpg http://mywebpages.comcast.net/wxgeek/p6100030.jpg http://mywebpages.comcast.net/wxgeek/p6100031.jpg http://mywebpages.comcast.net/wxgeek/p6100032.jpg |
06-13-2002, 11:47 AM | #2 |
SKINNY TIRES RULE!
That's wild. Was the truck in as serious accident at some point in it's life? Which half is the original?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
06-13-2002, 11:56 AM | #3 |
Did you try checking your option sticker in the glovebox for leaf springs? The pics you posted looks like what I have under my 72. Is it a shortbox or longbox? Maybe the previous owner shortened it? Seems the previous owner also converted from a 2 piece driveshaft to a one piece and found it was too low to clear the crossmember opening.
'72 C/10 LWB 402/400 Blaine, MN |
06-13-2002, 09:36 PM | #4 |
Re:My 69 C-10 Pickup
I'm posting an image of the spec sheet in the glove box.
http://mywebpages.comcast.net/wxgeek/p6130034a.jpg I also measured the wheelbase. Its 115 3/4 inches. Not exactly standard! This truck was sold as: 69 C/10 Pickup 350 CID w/TH350 tranny Jim M. |
06-13-2002, 10:53 PM | #5 |
the rearend,shocks,springs look correct for your year,the glove box says 127"wheel base,witch means you should have an 8'box .if it is still an 8'box then it may have been in an accident and repaired.and if you have a 6'box then someone shortened the frame. as best as i can figure anyhow, oh yea,is that a 2x4 piece of wood under the bed floor?
70 c10 stepside ,350v8, m-20 4 speed |
06-13-2002, 11:16 PM | #6 | |
Bloo
your truck is SUPPOSED to be a long bed, and if the wheel base is 115 inches, its been converted to a shortbed (even though you say the 3/4", factory shortys were 115)
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
06-13-2002, 11:37 PM | #7 |
According to your option list, your truck came with leaf springs. It is looking more like someone shortened the frame.
