06-12-2002, 07:12 PM | #1 |
What Front Brake Hoses To Use For 68 Conversion
Can anyone give me a part number or vehicle type so I can get brake hoses for the front of my 68 C10?
I swapped to disc but my brake lines are in the original location for 68. Many thanks, Peter |
06-12-2002, 08:07 PM | #2 |
My dad's 68
Go to auto zone...................thats where i got mine..................
$16.95 a peice though-ouch..................................Jack
Jack M. 67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts ****************************** 88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires 4 12 inch Lightning Audios ****************************** 87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ****************************** Dad's truck 68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more ****************************** grand dads truck 68 C-10 stepside fuel inj. 350/700R-4*soon in audi silver* ****************************** 84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames ****************************** S/N=BIGGYTYME@aol.com (hydros) "No fat chics, truck will scrape" |
06-12-2002, 09:27 PM | #3 |
brake hoses
Got a part number/brand for those?
06-12-2002, 10:00 PM | #4 |
Use lines from '71 or '72.
Scott70Chevy '70 CST: LWB, Fleetside, black ext., black/gray int., 350-4bbl, 3-speed, 12 bolt 3.07, deep dish rallye wheels, NO RUST! |
06-12-2002, 10:38 PM | #5 |
Yep, used 71-71 flex lines too
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
06-13-2002, 12:04 AM | #6 |
The best thing to do is get all new front lines from Inline tube. Cut the brackets offf rear of frame and re-weld to front in appropriate location for new steel lines and use 71-72 factory lines. That's what I did on my 70, but I cut the brackets off the donor truck so I can restore mine someday if I want (HA! I'll never go back to crappy drum brakes!)
06-13-2002, 11:19 PM | #7 |
Early Classic Products makes a hose specifically for brake lines on rear of crossmember (original position) when switching to disc brakes. Cost 55.00 a pair. You will also need a 3/16 line from proportioning valve to brake line tee cost 9.00.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
06-14-2002, 12:58 PM | #8 |
How is their conversion hose made any different?
