12-15-2019, 01:46 PM | #1 |
67 GMC Pontiac powered Project
My initial goal with this truck was a low buck project that can be driven and use up some stuff I have laying around.
Bought this for $700, Longbed stepside that the cab looked pretty decent, maybe just rockers. Rest of the truck is pretty beat but salvageable. |
12-15-2019, 01:50 PM | #2 |
Re: 67 GMC Pontiac powered Project
First order of business was to shorten the frame, This was pretty easy.
Not sure why pics are rotated, will have to look into that. |
12-15-2019, 02:09 PM | #3 |
I have a low mileage 400 Pontiac and 400 turbo I thought I would use it here.
Used 73 up frame brackets, with some minor tweaking, fit is pretty decent. Sorry about the rotated pics, They're straight on my computer, Used the search function to no avail |
12-15-2019, 02:22 PM | #4 |
Well the thought of not pulling the cab was short lived.
picture hosting sites Rockers, supports, floor section, Cab corner. |
12-15-2019, 02:28 PM | #5 |
Im in to see more .
12-15-2019, 02:29 PM | #6 |
12-15-2019, 02:42 PM | #7 |
12-15-2019, 02:47 PM | #8 |
Cool! So you used the 73 truck frame brackets and which motor mounts? Glad to see you posting. Keep up the good work!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
12-15-2019, 04:26 PM | #9 |
12-15-2019, 05:12 PM | #10 |
Wow! Good stuff!
Thanks for the photos.
01-25-2020, 08:37 PM | #11 |
01-27-2020, 12:48 PM | #12 |
What part of the drivers side mount did you have to cut???
GMC goofed when they stopped using Pontiac engines in 59 (?) THat 400 will be awesome in that pickup!!! |
03-07-2020, 09:22 PM | #13 |
It runs,
Sounds pretty good,I'm afraid I may have let the engine sit too long, A bit of a miss and smoke out the right exhaust. Hopefully it will clear up after I run it some more. Other progress, brake lines, rear brakes, E brake cables, most of the exhaust. Some wiring gremlins to deal with under the dash. |
03-08-2020, 01:35 PM | #14 |
Looking good! I like the blue and gold.
04-03-2020, 08:45 PM | #15 |
A little temporary progress, I bought another car and needed to clean out the extra bay of all the truck parts so I threw some parts together
Engine coming back out I bought this engine out of a 60k mi. rusty 72 Catalina. I figured I would take a chance. After running the engine, it had a miss that turned out to be a flat cam, and upon disassembly there is a little rust pitting in the cylinder bores .030 should clean it up, so now I'll do it right and rebuild it. |
04-03-2020, 08:59 PM | #16 |
Just here to tinker
Looks great buddy!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
04-03-2020, 09:02 PM | #17 |
Wasn't that long ago if you bought a new GMC it might have very well had a Pontiac Motor in it.
05-23-2020, 07:34 PM | #18 |
Got the engine running good today,
Bored .030 pistons, bearings,valve job,mild performance cam. I couldn't get it to run right with the old AFB, I had an Edelbrock intake and always wanted to try a Demon carb, which worked excellent out of the box. So, I'm back to where I was in March ready to make some progress. |
05-28-2020, 08:41 AM | #19 |
07-04-2020, 09:36 PM | #20 |
Some progress
Ran it up the gravel road seems to run good I got the front end together. The doors were pretty rough, so I got a set of aftermarket ones. There is a parts supplier is within 100 miles so I saved on shipping. Took the front fenders back off The right door went right on. The only left door they had was a customer return and he knocked $100 off it, so what the heck I took it. It took me two days to get it to fit. had to drill out the spot welds on the top frame and adjust to get it lined up plus a little hammer and dolly work on one edge Still need to work on the fender adjustments a bit |
07-06-2020, 11:16 PM | #21 |
Nice, I've had a couple of Pontiac 400's, good engines if you don't over rev them.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
08-01-2020, 08:25 PM | #22 |
08-01-2020, 09:38 PM | #23 |
I once owned a 55 GMC with a factory 287 Pontiac engine. I have a 317 out of a 56 GMC. once I installed a 301 Pontiac in a 72 chev. I have a 67 400 with the stick bell & flywheel Been thinking about putting it in my 82 chev 3/4 ton. Im a big fan of Pontiac engines.
05-06-2021, 02:10 PM | #24 |
Its been awhile any updates?
05-10-2021, 08:17 AM | #25 |
