Old 05-09-2002, 11:16 PM   #1
BigBlock67
Post How to change from points to HEI ?
Finally got the 402 in the '67. I need to change the wiring from the original points distributer to the HEI out of the '72 chevelle. I also have a kill switch that grounded the negative side of the coil. I think that would go to the tach terminal on the HEI but not sure. Any info would be a help.
BigBlock67 is offline   Reply With Quote
Old 05-10-2002, 01:40 AM   #2
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post
As for wiring the distributor, all you need to do is give it a full 12V, hot on start and run. Use a fresh 12ga or bigger wire. I don't think grounding the tach port would ground out the coil, though. Maybe it would, but it is just a tach connection, after all.
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 05-10-2002, 06:32 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Question
Where's the best place to hook that wire to? I just noticed that on my truck, whoever added the HEI, spliced the power wire into the old resistor wire. That's a no-no but I've been driving it this way for almost 5 years now with no problems.
63 Impala*66 Chevelle SS*69 Chevelle*69 C10 Stepside*71 Cheyenne 20*72 Chevelle
Parts for sale:
http://www.angelfire.com/trek/mr409/items4sale.html
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-10-2002, 08:28 AM   #4
69 longhorn
Post
The best/easiest place to hook the HEI power wire ,is to Ign unfused in the fuse box. Then just clip out the yellow wire to the soleniod,& the white resistor wire. As already posted ,use a 10 or 12 guage wire,you can cut a lenght of HEI feed wire from a boneyard special,& use a rubber grommet through the firewall. Some of the guys have also opted to use an inline fuse(I cant say on the size,mine is not fused). good luck......69longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-10-2002, 08:53 AM   #5
BigBlock67
Post
Longhorn, I see the yellow wire. Where does the white resistor wire come from and what does it do? Thanks for the replies.
Old 05-10-2002, 08:57 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
The white was the old coil positive wire.
The grounding cut off switch is something you are unable to do on an HEI. No point in it anyways. But, if you need a kill switch, just wire the hot lead from the IGN UNFUSED, to your cut off swith, then out to your HEI.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-10-2002, 09:24 AM   #7
BigBlock67
Post
Thanks Longhorn, That sounds like the perfect way to do it.
