01-19-2022, 08:25 PM | #1 |
84 c10 master cylinder help
New help purchasing the correct master cylinder and reservoir for a 84 c10 2wd. Truck has a LS swap if its important. Truck has 1" rotors. I tried going with the 2001 tahoe/s10 set up but didn't like how it brakes. Instead of holding on to the old set up I threw it away. Thanks in advance.
01-20-2022, 11:38 AM | #2 |
Re: 84 c10 master cylinder help
Here's the specs on an '85 (should be the same as the '84).
Part number 18008065 code ZF should be perfect (28.6 mm bore). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-20-2022, 11:55 AM | #3 |
