Old 05-31-2011, 11:40 AM   #1
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Speedometer gear reducer for 700r4
Hey guys, finally got my 700r4 installed and working. Now, my speedometer isn't working. Part of it just pulled apart so I know it was junk, and I probably lost pieces of the cable for the gear reducer, so I need to get a new one, but I assumed I needed a new one anyway. So the question is, what's the part number for the gear reducer to work with a 700r4, and a 3.40 rear end?
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 05-31-2011, 07:54 PM   #2
GM 4 Life
GM 4 Life's Avatar
Re: Speedometer gear reducer for 700r4
This might help you find what your after if you know the rest of your trucks specs. It helped me on my 2:73 to 3:73 gear swap. http://www.tciauto.com/Products/Tech...eedo_gears.asp
"Full throttle Silverado"
GM 4 Life is offline   Reply With Quote
Old 05-31-2011, 08:43 PM   #3
lindstromjd
That looks like it would work if I knew what the drive and driven gears were. I suppose I'll have to take the speedo cable output apart on the 700r4 to see what exactly it's talking about?
btw... your truck looks familiar. I take notice of every square body I see driving, and I swear I've seen yours around...
-357 / 700r4
-350 / TH350
Old 06-01-2011, 12:42 PM   #4
lindstromjd
Ok, I think I have this all figured out. First, I went here: http://www.transmissioncenter.net/sp...n_______va.htm and the picked out my transmission / rear end / tire height combo, and got the drive gear combination from there. So I ordered the correct combination of gears, and if I did everything right, I should be good to go from here. Now I just have to figure out how to switch out the drive gears...
-357 / 700r4
-350 / TH350
Old 06-01-2011, 07:37 PM   #5
GM 4 Life
GM 4 Life's Avatar
Here's 2 different sites that helped me and my buddy do my speedo gear swap. http://www.73-87.com/7387garage/drivetrain/spdgears.htm AND HERE http://www.thirdgen.org/speedogear I drive mine every day mostly in and around FWB, but she's minus that ugly camper top now. I too check out every square that I pass round these parts. Hope this helps man.
Old 06-02-2011, 11:37 AM   #6
jimbonice
jimbonice's Avatar
There is a great piece on this forums "faq" section . I'm doing a gear swap and found it extremely helpful.
http://67-72chevytrucks.com/vboard/s...d.php?t=322481
jimbonice is offline   Reply With Quote
Old 06-02-2011, 04:05 PM   #7
lindstromjd
Appreciate it. I ordered my new drive and driven gears just yesterday, so I'll be doing a little work here on it soon. I'm sick of seeing it sitting in a parking lot because I'm not driving it.
I didn't realize that write up was there. That will come in extremely handy. Thanks!!
-357 / 700r4
-350 / TH350
