Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 04-02-2007, 09:28 AM   #1
bw4sale
bw4sale's Avatar
Rust Neutralizer
The steel plate that the battery sits on in my lawnmower is trying to rust. My dad said you can pour baking soda and a little water on the rust to neutralize it, then spray it with Rustoleum Rusty metal primer and then paint. Anybody ever heard of this? Does it work? thanks.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 04-02-2007, 09:32 AM   #2
65-72 chevytoys
65-72 chevytoys's Avatar
Re: Rust Neutralizer
Yes baking soda is a acid neutralizer. If I remember my chemistry right you get sodium bicarbonate and a few other harmless by products then rinse and paints like you mentioned.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 04-02-2007, 11:00 AM   #3
WorkinLonghorn
WorkinLonghorn's Avatar
There's a better way and that is to rinse the area with lots of water and then apply "Naval Jelly" which is phosphoric acid. It forms a hard compound with the actual rust that is paintable and stronger than what was there. We used to use it all the time on an old steel ship I lived on and I can attest to it's value in restoring rusted areas to paint-worthiness.-Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 04-02-2007, 11:02 AM   #4
shifty
Questionable
shifty's Avatar
But, if it's the battery acid causing the corrosion, and you add another acid (Naval Jelly) to the mix without neutralizing, is that actually going to help?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-02-2007, 02:43 PM   #5
WorkinLonghorn
Good question Shifty.I don't know if any of the acidity would remain after rinsing. Rust itself is not acidic as you know, but I suppose I'd neutralize it just in case,then use the phosphoric.
Here's a link:http://www.corrosion-doctors.org/Met...-converter.htm
Old 04-02-2007, 03:24 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
Applying the theories of acids and caustics. The acid from a battery is very low on the Ph scale and the soda from baking soda is very high on the Ph scale--so they cancel each other out. I would first kill the acidic effects of the battery acid and then do the naval jelly thing. To seal the metal, I would look at a plastic based material or even get the piece covered with a rubber material like Rhino Lining or any other rubber based bedlliner.
