Old 03-07-2011, 09:21 AM   #1
Ricoh
Ricoh's Avatar
opinions on new setup for sb chev
Need some opinions on motor setup. I have a 1980 ish 350 chev block. It has been bored 60 over and has new pistons and rings and bearings ( do not know if they are stock or not). Bore was $200, pistons , rings and bearings ($300) , has all new rockers, springs . new double timing chain & sprockets. Camelhump heads were redone ($450) Cam is Crane cam Energizer ¾ race . Intake @ cam 3134 @ valve 470 duration 282 , Exhaust @ cam 3134, @ valve 470, duration 282, recommended RPM range 2500- 5500 , float 6500. Intake is a Weiand Stealth 8016, carb is a Holley 1850 –600 CFM carb. I want to upgrade a bit. I picked up an Edelbrock Performer RPM intake at a good price , new in the box, and was wondering what carb I should go to , whether I should stay with the Weiand and a new carb ?????? Don’t want a rocket, just want to maybe increase performance a little and make it look better under there. I will be pulling the motor in the spring to strip and paint it .The motor ran strong when I bought the truck 7 yrs ago and began the build.
Rick
80 chev, 350-300 hp, 4 speed. All torn apart now
Ricoh is offline   Reply With Quote
Old 03-07-2011, 12:26 PM   #2
Ticker
Re: opinions on new setup for sb chev
The Stealth is a high-rise, dual-plane design and a good one. I would see zero benefit in a manifold swap. Your carb sizing is fine.
If I was looking for more power, I'd look at a cam swap depending on your gears and trans. That cam is really a racing cam set up to deliver top-end power rather than low-end grunt - and as a single-pattern it's not the best fit for the stock heads as they need a bit more help on the exhaust side. I assume you're running headers and a good exhaust...?
I believe this is the cam in question based on the specs for anyone else that wants to comment...
http://www.cranecams.com/product/car...detail&p=23945
Ticker is offline   Reply With Quote
Old 03-08-2011, 02:10 AM   #3
Captainfab
60-66 Nut
I agree on a cam change. Those Energizer are old school grinds. There is power to be found with a more modern grind from either Comp Cams, or Lunati. Like Ticker said, we need more info to give a recomendation on a cam.
Old 03-08-2011, 10:21 PM   #4
Blue Rat
Myself, I would go with a little more lift. More like http://www.summitracing.com/parts/CCA-CL12-242-2/
with just a little more carb too.
Blue Rat is offline   Reply With Quote
Old 03-08-2011, 10:24 PM   #5
Ticker
Why?
Old 03-08-2011, 10:41 PM   #6
Blue Rat
Originally Posted by Ticker View Post
Why?
Have put that cam in several small blocks in the past. Seems to turn on a little quicker an a little more user friendly than what he has listed. Get more use out of his rpm range for what he has listed. Simply on the carb, I would just want a little more carb.
