02-13-2016, 07:41 PM | #1 |
12 valve swap!
Hi all, going to try to go for a 12 valve swap within a year. I've gone to the diesel conversion section and looked through a bunch of threads and there was a specific one that was I believe a c30 and he used auto world mounts. The mounts look pretty straight forward but I just couldn't see what he did for the perches. Are they the stock ones? Built? Bought? Someone clear this up!! Thanks a bunch.
02-15-2016, 01:26 AM | #2 |
Re: 12 valve swap!
Are you wanting to put a 12V in a ½ ton? If so, it is a bad idea unless you box and reinforce the frame.
1991 V1500 Blazer (Silverado), 5.9L 12V P-pumped Cummins (5x .012 sac injectors, #6 fuel plate, WH1C with external 38mm wastegate running 30psi), NV4500 with 1-⅜" input shaft, SBC Con-O clutch, NP205, HAD, 4.10 D61/14BFF spinning 37" Nitto Exo's "I got a shotgun, a rifle, and a four wheel drive and a country boy can survive." |
02-15-2016, 01:39 AM | #3 |
Re: 12 valve swap!
A cummins 12v swap in the 67-72 is a really tight squeeze requiring either firewall rebuilding or stretching the front out. PLUS frame work. If I remember right the engine pushes 1200lbs with coolers and everything
02-15-2016, 10:29 AM | #4 |
Re: 12 valve swap!
If we knew what thread you are talking about we might be able to answer your question. We need to see what you saw. It would help to now what truck you have and what engine it came with
02-15-2016, 09:39 PM | #5 | |
6>8 Plugless........
Re: 12 valve swap!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-16-2016, 04:07 AM | #6 | ||
Re: 12 valve swap!
02-17-2016, 09:38 PM | #7 |
Re: 12 valve swap!
Max, it does vary but my manual shows 1020 dry and that's with no a/c comp, alt, vacuum pump/ps pump. The 950 is not accurate for a complete engine. I've weighed them a few times trying to shed some weight off one for a car.
http://cumminshub.com/12v.html
02-18-2016, 01:48 AM | #8 |
Re: 12 valve swap!
My info comes from Cummins' own B-series shop manual. It says "Engine weight (with standard accessories): 6 cylinder engines ..... 410 to 440kg [910 to 970lbs]"
Perhaps "standard accessories" only means a water pump?
03-24-2016, 07:03 PM | #9 |
Re: 12 valve swap!
Hi guys, sorry I haven't really been on much but his username is kobush. The install looked so clean especially the mounts. My truck is a 70 c10 original with a 307/3 on the tree. Still the 307 with some goodies and a t5 behind it.
03-24-2016, 08:39 PM | #10 | |
Re: 12 valve swap!
http://www.cumminsdieselrepowers.com/
03-29-2016, 10:31 PM | #11 |
Re: 12 valve swap!
So is that set up mounts/perches from autoworld? Or mounts are auto world and stock perches?
03-30-2016, 12:47 AM | #12 |
Re: 12 valve swap!
Auto world does not use stock upper mounts. (Perches) You will get new fabricated upper mounting brackets, and a poly engine mount. Per side.
04-11-2016, 01:04 PM | #13 |
Re: 12 valve swap!
Cool thanks!
