08-18-2021, 10:08 AM | #1 |
1972 BLAZER Upper Trim ???'s
Looking to install both lower and UPPER trim on my K5 Blazer build
1. don't believe that K5's were factory with the upper trim option however I have seen K5's with both lower and upper. 2. Do you these builds that have upper use SHORTBED or LONBED upper trim? 3. Looking to order but want to order the correct trim - heard that Mar-K makes the highest quality? thanks guys
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
08-18-2021, 10:14 AM | #2 |
Re: 1972 BLAZER Upper Trim ???'s
some build pics
08-18-2021, 11:56 AM | #3 |
Roadtrip!
I think shortbed trim will work. Just need to cut it to fit. There should be a piece that finishes the cut end that comes with it.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
08-18-2021, 04:16 PM | #4 |
I would talk to Mark k and see if they have suggestions. From what I have read their trim is better than nos.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
08-20-2021, 03:23 PM | #5 |
anyone have specific contact for Mark K
08-24-2021, 01:00 PM | #6 |
08-24-2021, 09:24 PM | #7 |
I don’t think I’ve ever talked to anyone but I have seen builds with their upper trim over the years. I think it’s a matter of either cutting one of the trim pieces to fit or maybe they offer it ready to go.
08-25-2021, 11:31 AM | #8 |
HAha - I thought Mark K was a person - its the company hahaha
Other question - does the short bed uppper trim that goes on the bed have an end cap? I know the long bed trim does
08-25-2021, 10:57 PM | #9 |
I am getting ready to do upper and lower trim on a 71 blazer and from my research you use the upper trim for a longhorn as it has a 6 in piece that goes on the rear so you just cut to length then you that piece to finish it off. I just ordered mine from marK but they are about 6 weeks out. So we will see when it gets here.
08-26-2021, 04:21 PM | #10 |
I got NOS upper Trim for a long bed, Were the molding comes apart I cut mine down to fit exact .
09-30-2021, 06:11 PM | #11 |
"Ochre Ogre"
I have supplied trim for about a dozen "Cheyenne" version Blazers. We do the upper short bed kits without the cab corner pieces. The upper bed molding has 3 pieces. It has an end finish extension with spline that you can remove, shorten the long piece, and reinstall to make the correct length K5 upper molding.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
