Old 03-24-2014, 10:50 PM   #1
ClassicGuy
Cool Differential question
I have a 70 c10 short bed. It has a leaf spring rear end right now but I want to change it to coil spring rear end. I can't find any coil speing rear ends for my year. Can I use a rear end from a newer truck like 73 or newer?
Thanks guys
ClassicGuy is offline   Reply With Quote
Old 03-24-2014, 11:57 PM   #2
Fitz
Re: Differential question
Thanks guys
Currie sells the trailing arm pads and shock mount brackets to convert your axle from leaf to coil. Use those and you know you have a good diff or, buy a used diff which is always a crapshoot. Your choice.
Fitz is offline   Reply With Quote
Old 03-25-2014, 12:15 AM   #3
ClassicGuy
Is there a website for currie?
Old 03-25-2014, 06:23 AM   #4
PGSigns
PGSigns's Avatar
I would post in the fore sale section you need a rear end. There are lots of them out there and the guys here can help you find one. 70 still used the narrower of the 12 bolts and in 71 when they went to 5 lug it got an 1 12" wider so keep that in mind. You can get the mounts from vendors right here on the board if you go that way. But finding a donor frame or truck to get all the parts off of may also be a good route to persue.
Jimmy
The brackets
http://67-72chevytrucks.com/vboard/s...d.php?t=620836
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-25-2014, 06:49 AM   #5
Keith Seymore
Keith Seymore's Avatar
I suppose you could, but be advised that '73 and up were always leaf (never coil), so I'm not sure what you would gain.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-25-2014, 06:56 AM   #6
andrewmp6
The axle saddles you need are 39 bucks from early class http://www.earlyclassic.com/catalog.aspx part number #02-8005 and the u bolts are 40 bucks part number #02-9000
Old 03-25-2014, 10:33 AM   #7
ClassicGuy
Thank you guys for the great info.
Old 03-25-2014, 11:52 AM   #8
69gmcc10
69gmcc10's Avatar
ClassicGuy,
Your original post asked if you could use a 73 rear end and the answer as previously stated is yes they are the same width as some late 70 rear ends, all 71-72 and 73 and later square body trucks. With weld on axle saddles form ECE and a little research here on where to mount those saddles on the axle you will be just fine. For some reference on how I converted my 69 to trailing arms take a look at my build thread and dont be shy about asking questions.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 03-25-2014, 12:16 PM   #9
65Gregg
65Gregg's Avatar
I believe CaptainFab sells the saddles as well, check the parts section.
try this link
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
