Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 04-03-2004, 12:46 AM   #1
70c10
67-72 Addict!
70c10's Avatar
Arrow Post your GM part numbers here
I figured we should have a thread for factory part numbers for easy reference. Anytime you get a receipt from the dealer try to list the part number and name of part here. It doesn't matter how small the part is. It may help a fellow board member who is looking for an "oddball" part!. Lets try to keep this as simple as possible. Heres a few I have bought for my 70'. I hope these are valid everywhere, otherwise this post is useless.
Upper steering column bearing - 5679205
Chrome turn signal lever - 3909580
Turn signal switch - 1972751
Turn signal switch harness assembly for the above switch - 1894851
Turn signal cancel cam - 3902190
Detent seal for detent cable - 1262475 (350 turbo)
Transmission filler tube seal (top hat later style) - 1259475 (350 turbo)
Transmission filler tube seal (O-ring earlier style) - 6264902 (350 turbo)
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline
Old 04-13-2005, 05:14 PM   #2
Spoof
Spoof's Avatar
Exterior door handles
#3927899 and #3927895
I read this on another post, can't vouch for it and I don't know which is left or right.
71 GMC 1500 LWB
Spoof is offline
Old 05-03-2005, 02:39 PM   #3
blink32
blink32's Avatar
For 1973 1974 1975 1976 1977 1978 1979 1980 (as far as I know)
Fender right 14031990
Fender Left 14031989
Hinges 6262007 & 626008
Hood 15576465
passenger bedside 15597624
blink32 is offline
Old 06-02-2005, 08:37 PM   #4
70GMCer
70GMCer's Avatar
Here's the upper alternator mounting bracket for 67 thru 72. Still available as of this posting...... 3951338
Steve
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline
Old 07-13-2005, 04:31 PM   #5
70GMCer
70GMCer's Avatar
That bracket is the adjustment arm and for the drivers side and for a short water pump....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline
Old 11-26-2005, 09:30 PM   #6
chops333
Re: Post your GM part numbers here
plug in harness for van tilt to 67-72gm no.1894851 flat to horseshoe
chops333 is offline
Old 12-28-2005, 03:25 PM   #7
86dieselburb
73-87 headlight switch GM #1995217
GM PartsDirect has it for $16
Classic Industries has it for $30
86dieselburb is offline
Old 01-01-2006, 01:59 AM   #8
67sss
67sss's Avatar
Don't know if you can still order these but here you go:
3917809-stainless cab trim-under the back window
3997463-Longhorn upper bed pass. side molding..pic included
67sss is offline
Old 11-11-2006, 08:53 PM   #9
magnethead
7000 #'s of american IRON
magnethead's Avatar
73-80 (may be full run to 87, not sure) Roof Marker LENS 7505068
magnethead is offline
Old 11-11-2006, 11:06 PM   #10
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
GM must have changed #'s again, the 5 cab light lenses I bought for my truck are part #684662 in the new style box. Here's some more in case you guys need specific ones:
Roof marker lens gasket, 69-72 Gr. 2.575-#12337943 (new # should be availbile at your dealer, old one is 3942898)
Window regulator handle, 69-72 Gr. 10.797-#20348200
Gas tank neck grommet, 67-70 Gr. 3.008-#3886792 - this is a good # that any dealer should be able to get
Winshield wiper switch, 2 speed, #1993432
Door handle escutcheon(black, paint to match), Gr. 16.270-#3939997
Brake light switch, Gr. 2.4447-#1261219
Windshield washer hose grommet(goes on firewall), #3746483
Interior mirror cover(usually black, I have two NOS and one is dark metallic green from GM), 69-72 Gr. 16.069-#3971007
Heater control switch, Gr. 8.852-#3840039
Hockey puck cab lens, 69-70 #5961757
Rear red sidemarker light, 69-72 Gr. 2.575-#916087
Front amber sidemarker light, 69-72 Gr.2.575-#915788(had three #'s on the box, all crossed out except this one)
Clutch rod swivel, 67-72 Gr. 0.787-#3918467
Deluxe Delco radio knob, 69-72 #1991087, also has 1991072 on the package
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline
Old 11-13-2006, 09:04 PM   #11
centsless
sufficiently talented fool
centsless's Avatar
Sport mirror part #'s. The mirrors and gaskets were still available thru GM about a month ago.
Left side mirror - 3981409
reinforcement - 6263291
gasket - 3987127
Right side mirror - 3981410
reinforcement - 6263292
gasket - 3987128
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline
Old 11-18-2006, 11:57 PM   #12
mtndewmaniac66
Do the Dew!
mtndewmaniac66's Avatar
Originally Posted by WLPTMP View Post
i'm a gm parts manager if u guys need any part numbers let me know from 29 to present.
If I can relocate some of the papers that I wrote my 327 part numbers on, I just might hit you up on your offer. I have been informed by the previous owner that my truck came with a factory ordered, blueprinted 300HP 327. The number on the glovebox, and the spec sheet lists the engine option 04L30AC. (It has been 8 months since I saw this number, so I hope it is correct).
mtndewmaniac66 is offline
Old 11-27-2006, 04:51 PM   #13
wildmanaaron
If possible could all of the 73-87 and related part numbers be posted here as well? Thanks!
http://67-72chevytrucks.com/vboard/s...d.php?t=216274
wildmanaaron is offline
Old 01-20-2007, 08:39 PM   #14
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Eaton 12 bolt car or truck posi. These are the only parts that are the same between car and truck posi.
Eaton posi clutch pack. 12524505
Eaton posi springs Green 50lb 3890899
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline
Closed Thread
