Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-17-2009, 12:15 PM   #1
gene_ensor
gene_ensor's Avatar
2 1/8" Primary Headers
Please help me source some 2 1/8" primary headers for my 69 with 74 bbc engine mounts. The AFR315 fully ported heads need to breath. Thanks.
gene_ensor is offline   Reply With Quote
Old 12-17-2009, 12:45 PM   #2
Alex1
Alex1's Avatar
Re: 2 1/8" Primary Headers
i don't think they make an off the shelf header for our trucks in 2 1/8
Alex1 is offline   Reply With Quote
Old 12-17-2009, 02:18 PM   #3
ripdog28
ripdog28's Avatar
Hooker Comp for Chevelle is 2in primaries and 3 1/2 in collector and fits our trucks sliding inside the frame rails. Should be fine unless you have crazy HP 800+..
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 12-17-2009, 02:30 PM   #4
royo
royo's Avatar
see if you can use anything from here
http://www.lemonsheaders.com/products/bbr-545.htm
or
http://www.lemonsheaders.com/products/bbpt-610-615.htm
look at this
http://speedtalk.com/forum/viewtopic...0a26c79bbfef7a
nickle and dime
royo is offline   Reply With Quote
Old 12-17-2009, 08:04 PM   #5
69trk
69trk's Avatar
I have the hooker supercomps with a 2" primary and a 3.5" collector and are equal length, they fit pretty good for an equal length and they flow good...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 12-18-2009, 08:29 PM   #6
gene_ensor
gene_ensor's Avatar
Has anyone had success or disaster with these in a 67-72 bbc 2wd, bb engine stands, with standard components up front? My preference is the first one.
Hooker Super Comp
2220HKR
http://www.summitracing.com/parts/HOK-2220HKR/
2265HKR Black
http://www.summitracing.com/parts/HOK-2265HKR/
2265-1HKR Ceramic Coated
http://www.summitracing.com/parts/HOK-2265-1HKR/
You guys can debate the 2 vs 2 1/8 advantages, but I am past that. Both AFR and Dynomation indicate the 2 1/8 for my setup, and will be implementing N2O on top of that. Dont get me wrong, good discussion, but I'm stuck with a build in SD and a fab shop in CA right now. Thanks.
Old 12-19-2009, 01:45 AM   #7
royo
royo's Avatar
I would have someone build me a set. That way i get what i want an don't have send a set of headers back that don't fit?
nickle and dime
Old 12-19-2009, 06:27 PM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Air male posted before that chevelle 2 1/8 headers work. Ill see if i can find the post. My mistake 2" sorry
Old 01-09-2010, 01:58 PM   #9
daviddavid6000
mt
daviddavid6000 is offline   Reply With Quote
Old 01-09-2010, 02:05 PM   #10
daviddavid6000
could you give me a part number for these headers or application such as what year chevelle im guessing 70 ish ?
and does the collector hang down like right bellow the bottom frame rail where you would have enough room to bolt mufflers directy to them
i have a very similar setup 72c10 big block and same heads and i came up with chevelle headers would be the cheapest way to get somthing bigger than a 1.75 " primary
Old 01-09-2010, 02:45 PM   #11
nxtruck
nxtruck's Avatar
To the O.P.,
you may try calling Tom Dawson Racing Headers. About 15 years ago, I had them make a set of 1 7/8 x 3 1/2 custom headers for my '66 with a sbc, and the headers fit like a glove. Tom used to be an engineer for Hooker and he would take a set of headers for a specific application, set them up in a jig, and duplicate those headers in whatever size pipe you want. I have nothing but good to say about them.
Their shop is located in Nuevo, Ca. and their number is 951-928-0969.
Good luck with your build!
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 01-13-2010, 10:26 AM   #12
Alex1
Alex1's Avatar
Hooker makes Super Comps for 73-87 trucks with 2" primaries, would that work for you?
Old 01-13-2010, 10:29 AM   #13
Alex1
Alex1's Avatar
http://www.holley.com/types/Super%20...WD%20Truck.asp
2841-1HKR
68–87 Chevy/GMC 1/2, 3/4 & 1–Ton Truck, 68–91 Blazer/Yukon/Jimmy/Suburban/1–Ton Crew Cab: 396–502
Full Length Header Tube Size 2" x 35", Collector Size 3.5", Collector Length 10", Port Shape: Same As Port, Metallic Ceramic Coating
2841HKR
Full Length Header Tube Size 2" x 35", Collector Size 3.5", Collector Length 10", Port Shape: Same As Port, Black High temp paint
Old 01-14-2010, 07:36 PM   #14
AirMale
AirMale's Avatar
the problem with the headers "DESIGNED" for these trucks is that they hang down very low. The hooker #2455 work for me in a slammed 2wd auto with b&m shifter. 2" primary should be more than most need in a header, for everyone else $$$custom$$$
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 01-18-2010, 10:14 AM   #15
bigboybodry
bigboybodry's Avatar
I have the hooker super comp headers for my 1970 truck with a bbc and they do not hang down.Work well with my combo but i am not sure about yours. I think that the exhaust runners are raise on that head? If so its gonna be in your best intrest to have a set built like royo said. because of the clearence problems with the headers being moved up with the exhaust ports being raised. Are you running the engine in the stock location with the 1974 engine mounts? there is several factors to take in consideration just trying to make sure you look at everything before you order something you cannot use.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 01-20-2010, 12:15 AM   #16
MONTE
MONTE's Avatar
Question Re: 2 1/8" Primary Headers
What did you guys use to make it work. I ordered some super comps
2841 headers? Motor mounts??
MONTE is offline   Reply With Quote
Old 01-22-2010, 05:57 PM   #17
Alex1
Alex1's Avatar
Report on how those fit once you install them!
Old 01-22-2010, 07:33 PM   #18
ripdog28
ripdog28's Avatar
David6000,
Sorry about the late response. Check out the link in my signature, i have some photos in my build. They are #2455. I only had problems on the driver side. A little ball peen hammer fixed it in about 2 minutes. It was hitting my lower cont arm was all.
69 c-10 BBC
