Old 03-12-2018, 01:50 PM   #1
justinws6ebay
68' C30 Brake conversion
just recently acquired a 1968 C30 1 ton dually. I would like to do a disc brake conversion but all i can find is information for C10's and C20's. The C30 is an 8 lug and i was wondering if the C20 8 Lug was the same set up. where i can directly bolt in C20 disc brake kit... any help in this matter is greatly appreciated.
justinws6ebay is offline   Reply With Quote
Old 03-12-2018, 02:31 PM   #2
JustToxic
JustToxic's Avatar
Re: 68' C30 Brake conversion
If I remember correctly, the C30 and C20 stuff is pretty interchangeable. If you have a dully I know you'll have to get different rotors, but everything else should be interchangeable.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 03-12-2018, 07:09 PM   #3
projectking
projectking's Avatar
Squarebody spindles, rotors, dust shields, and ball joints will all work on your ‘68 control arms. 20/30 are the same as long as it’s not a cab and chassis.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 03-12-2018, 08:02 PM   #4
hugger6933
If your truck has dual rear wheels get your parts off a
c30. The things you have read about conversions using squarebody parts will work it is just bigger and heavier. Try to think this way 10 to 10, 20 to 20 and so on. That will make a huge diff in you old heavy hauler. Enjoy.
hugger6933 is offline   Reply With Quote
Old 08-25-2018, 06:02 PM   #5
Chris7112
I have a 68 GMC c3500 and I acquired a set of 77 c30 disc spindles. Will these work with the 68 ball joints? Tried to find the difference at my local parts store but the weren't much help since they had neither years of ball joint in stock and the do not have any spec on length/with of ball joints available.
72 chevy k20
72 chevy k20 on rockwell's
68 GMC3 c3500
69 GMC k20 353t detroit
Chris7112 is offline   Reply With Quote
Old 08-26-2018, 12:36 AM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
At least for drum brakes, all the 1T stuff is bigger. I'd expect the same for the disc brake parts, but I have no experience with it. Maybe if you keep looking at parts stores, you will eventually find a counterman who knows his stuff. I had to visit the local NAPA several times until I finally got my 3/4T rear brake adjuster components. Some were boxed wrong Chineseum was most of the problem.
~Steven
Simi Valley, CA
8 lug, c30, disc brake conversion
