Old 07-13-2014, 06:55 PM   #1
Buddy Malone
Swapping big block for small 71 4x4 3/4 Suburban
I know it's been asked before but I'm throwing it out there again. I'm installing a 502 in place of a 350 in a 4x4. The body is off, I'm also installing an Art Carr 4L60 trans. I'd like to keep transfer case in same location, moving motor about 2 1/2" forward. I'd also like to use original crossmember and towers. I have a 71 4x4 truck that I swapped 4 speed for 400 AT. Left transfer case moved motor forward all good, I'm hoping to have the same luck. Any help would be greatly appreciated, thanks.
Buddy Malone is offline   Reply With Quote
Old 07-14-2014, 12:56 AM   #2
Livrat
Member #1049
Livrat's Avatar
Re: Swapping big block for small 71 4x4 3/4 Suburban
2 1/2" inches forward for the big block is just about perfect.
Then you can use a stock small block fan shroud, the only thing you will need to keep in mind is the oil pan clearance to the engine mounting cross member, if the pan has a single drop to the sump you will be fine. but if it has a "double" drop you will have issues. (A stock 68-72 truck big block pan is good) an early 65-70 Impala pan has the double drop and will not work without mods.
Livrat is offline   Reply With Quote
Old 07-14-2014, 01:48 AM   #3
SierraMtns
SierraMtns's Avatar
When a Big Block is being put in a C10 it is required to have a build thread...lol
No for real we want to see that 502
Welcome from NorCal.
SierraMtns is offline   Reply With Quote
Old 07-23-2014, 08:37 PM   #4
kitsbeach
kitsbeach's Avatar
I agree
kitsbeach is offline   Reply With Quote
