Old 04-17-2005, 07:06 PM   #1
chief bobber
Sanity is a state of mind
chief bobber's Avatar
Question for this forum, frames
As you guys & gals have seen, I've be posting looking for a two wheel drive frame for my panel. I thought that panels ,burbs and long well base pickups (8Ft.) were the same creature. Now Special -K tells me that they are indeed different.
Originally Posted by special-K
Just a suggestion.You might be better off with that `Burb/panel frame and just swap-in the discs.Were you getting drop-spindles anyway?The PU frames have different contours.Its easy enough to come up with the rest of the disc set-up.
Darn that throws a wrench in the works. My Question, would it be a lot of work to make it go?
Regards, KC
P.S.
Here is a picture after a $23 paint job
67 K-10 8ft step 250/465/timken 4 shaft/373 to 1
70 C-10 Panel Vortec V/5spd BW od /307 to 1
70 C-30 9ft stepside dump 350/465/ posi
and a few too many other trucks, cars, jeeps, cruisiers, and M/Cs
...o~`o
chief bobber is offline   Reply With Quote
